Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
My shampooer wont release the water or cleaning solution
  • 1,040 Answers
Here is a Link to one of my Tips that should help you:
www.fixya.com/support/r6323257-bissel_carpet_cleaner_dispense_water
Good Luck!
Jim
Posted on Oct 11, 2010
  • Jim Parker
    Jim Parker Oct 17, 2010
    Was this helpful?
    Jim
Why doesn't my shampooer release shampoo or water?
Hello, The main reason it won't release is there is a hose or orfice that is stopped up, will have to be taken apart and cleaned.
Nov 10, 2015 | Vacuums
Shampooer wont spray water!
be sure you arefilling the correct resivor
I did that on a friends that I borrowed
Nov 20, 2013 | Vacuums
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
Been cleaning for 2 hours now with my Bissell Quicksteamer and on my next run i presses the water release trigger on the handle and water isnt being squirted on the carpet..why?
ran out of water? (if water) >
Is there some form of water filter?
Problem with the trigger?
Bad steam heating element or the power connection supplying the power to it?
Of could it just be tired and need a break? (grin)
Best Regards
Ck
Aug 16, 2011 | Vacuums
I have never used a shampooer before when I use it it says to empty out dirty water. I don't have any left. My tank is empty. Am I doing something wrong.
Suggest that you do the following.
Remove the TOP ("Clean water") tank. Fill it 1/2 full of water. Put the top on the clean water tank and place it back on the machine.
Release the machine handle and remove the cover of the "dirty" water tank. Inspect the back of the tank to be sure that the vacuum adapter in located in the rear of the dirty water tank. If not-that is your problem. If yes, restore the top to the dirty water tank.
Power the machine on.
On a kitchen floor, power the machine on. Pull the trigger and hold it for about 30 seconds. You should see water gathering around the brushes. If not, that is a problem.
With water around the brushes, release and lower the handle and and move the machine over the water. It should vacuum the water into the dirty water tank.
Is all of that happening?
Nov 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Bissell carpet shampooer priblem
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes.
Jan 17, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Jun 01, 2008 | VAX Appliances Vacuums
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
