Question about Philips Televison & Video
The power won't come on,when turned on i just hear a clicking sound from the power
  • 1,476 Answers
Jimmeitir,
Your problem could literally be anything, but I like to approach problems scientifically. If I had to guess I would say that the problem is in the high voltage power supply since it is the hardest working section. You did not mention the model and I am assuming that it is a CRT based projection TV.
I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which walks you through the process and should help you find the problem and fix it. My tip also has recommendations for where to get the parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 11, 2010
When I push the power button on the tv I hear a click and then another click but the tv won;t turn on. The white led on the front comes on momentarily the goes out. I have replaced the power suppy boa
sounds like a capacitor sometimes they look fine but don;t work. I had this problem in my lg replaced 3 caps and it fired up. caps are cheap.
Jan 23, 2015 | Televison & Video
I have a 1977 Suzuki GS400X, I get power to all
you may have a bad flasher needing replacement. just because you hear it click when you turn on the signals does not mean the bi-metallic strip inside is working.
Sep 21, 2014 | Cars & Trucks
My 2000 Pontiac Montana won't start. I hear a clicking noise from the back but the starter doesn't engage
have somebody hit the starter with a hammer while somebody turns the key on the start position as he holds the key keep hitting the starter not at the solenoid at the round part if it tries to start then you have a defective starter now if you have a alarm system you are going to have tutoo isolate the starter to do a different test.
Apr 16, 2013 | Cars & Trucks
My 1996 Toyota Vienta won't turnover with the key in ignition. Plenty of electrical power, air con runs as does the lights. Fitted with an immobilizer, wondered if that might have something to do
Check wiring to your starter make sure all the wires are secure. Its mainly sounds like you need a new starter. If you hear it clicking it is likely engaging just not spinning
Feb 15, 2013 | Cars & Trucks
TV won't turn on. I hear a clicking noise near the power supply. I have no picture or sound
This is usually and most likely caused by the power inverter/board. There are capacitors and other components that can burn out and will cause the power not to be transfered correctly
Jun 06, 2012 | Sony BRAVIA KDL-52W3000 52 in. LCD...
2005 Altima won't start, hear clicking sound coming from fuse box,key stuck in ingintion,won;t turn over,tried to jump start.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
May 30, 2012 | 2005 Nissan Altima
My 2006 Jeep Liberty won't start or turn over all I keep hearing is this click sound when I turn the ignition , Plus I just replaced the battery........What shall I check next?
check your starter,better yet has your alarm system been activated and possibly shut down your car a passive alarm will do that
Mar 27, 2012 | 2006 Jeep Liberty Limited
When trying to start my 1999 GMC Jimmy I turn the egnition and all my aux. lights turn on and everything works, but there is no power going to my starter, it doesn't make the clicking sound and it...
check for power to starter solinoid, if power to there. then it has to be a bad starter solinoid or starter. checker solinoid first. if bad you will not hear any clicks or anything.
Sep 11, 2011 | 1999 GMC Jimmy
I have a Hayward ABG100 pool heater that won;t turn on. I hear a faint click when I turn it on but no blower or ignition to follow. Power and flow are fine. Is this a bad ignition module?
It sounds to me like you're looking in the right direction with the ignition module.I would replace it and then see what happens.Thank you
Jun 20, 2011 | Heating & Cooling
Televison & Video Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
