InFocus LP 70 Multimedia Projector Logo
Posted on May 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PAL support I have a 5-year old Infocus LP-70 (I am in Europe now and I THINK it is 70). Does it support PAL DVD as played by a player?
Anonymous
Level 2:
Scholar:
  • Expert 167 Answers
  • Posted on Dec 30, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
167
Questions
0
Helped
65952
Points
330
Yes the LP70 and the LP70+ both operate perfectly with a PAL source. Also the will operate just fine using 220vac 50hz too.
Cheers
What format is used when the VHS is copied to the DVD ? I have copied the VHS tapes onto Verbatim DVD-R discs. They will not play on my computer. Verbatim says I need to know what format they are in...
the most common in the US is NTFS. another used in other countrys is PAL. the format is seperated into regions, and they are as follows,
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
you can use MAGICdvdRIPPER softwareon your computer, it works with NTSC, and PAL formats and vice versa.
What is the country code for australia - lg dvd recorder
The geographical regions are as follows:
REGION 6 -- China
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs.
Hope this information is useful to you.
1helpful
When you insert a dvd it says PAL DISK
PAL is the format of the dvd and there are two main formats for a dvd and they are PAL or NTSC. The NTSC format is mostly used for the United States, and the PAL format is used more in Europe and Asia. An older dvd player will have the format options in the setup menu for the dvd player, and from the setup menu on the tv screen the dvd player can be set to play the PAL dvd's. However if that is not the problem and the dvd player no longer can tell a PAL from a NTSC format then the dvd player either needs a serious lens cleaning or it has a malfunction. Also, the back of the cover for the dvd should say if it is PAL or NTSC.
3answers
The player says wrong region code with every dvd i have!! help please Phillips 3020K
Where did u bought this DVD player?US,Canada,and Mexico?The DVD disc. used NTSC region format.Asia,Europe,Africa,and the Middle East.The DVD disc. used PAL region format.They can't be mix or it will not play as u find out.If u move in and out to another region of the world.U must have a regions free DVD player to play either NTSC or PAL regions.
APEX DIGITAL AD-1500 unit
It play all regions in US an Canada it in NTSC software format.All US,and Canada in softwares it this regions.Europe in PAL regions,and Asia play in that format PAL too .
I bought a dvd player cobusa model dvd-224. the box stated that it can play Pal and NTSC dvd discs.How does one setup for pal region 5 disc? When I setup for pal I get a rolling black and white picture...
Check to be sure that the setup is correct. The picture you are describing is what happens when you play PAL into an NTSC unit. I don't think you are in PAL mode.
Dan
1helpful
Re: assistance
DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
REGION 6 -- China
REGION 8 -- Resevered for Cruise Ships, Airlines, etc...
DVD FROM EUROPE
Because it's been recorded using Pal or Secam...Try this site to make your recorder "Multi-region";
http://www.dvdexploder.com/how.htm
2answers
My DVD player, stopped playing in color!
check to see if the coding is set to PAL or NTSC, when watching in PAL, NTSC shows up in black and white. ( NTSC is normal for the USA and a hand full of other countries... PAL is used in ASIA, EUROPE, and most everywhwere else).
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
