Question about Hitachi 61SBX59B 61" Rear Projection Television
Hitachi 61SBX59B I unplug the unit, plug the unit back in and the green lights come on and then with in three seconds the unit shuts off!
  • Hitachi Master
  • 5,138 Answers
Replace Both of your STK ICs STK392-110 use 120s
Mats has them 1-800-628-1118
Posted on Oct 11, 2010
  • 6 more comments
  • imsureru Oct 11, 2010
    By the way Hi, So you think it has nothing to do with the power supply, or did this just have to do with the banding issue. Please advise!
  • ladywinn
    ladywinn Oct 11, 2010
    Before you replace ICs check D957, it is a 15volt Zener Diode. if it is Shorted Set will shut down.
    Regulator/power supply circuit . Google to Encompass Parts Distribution Type in your model # they have Free Service Manual that you can print out online,they also list Parts /Prices to this Model# 61SBX59B
  • imsureru Oct 12, 2010
    Here is the summation of the whole problem sorry for not posting first.
    My Hitachi 61SBX59B over the last few months has been acting funny like turning on the tv and no sound but was corrected by changing the channel. Then while that went on I also developed a type of banding, like if you watched CNN or Fox News and the bullets at the bottom of the screen would be pulled to one side or the other with little ghosting at those edges. Then it started at the top as well, most prevalent when tickers or bullets were on the screen both top and bottom. Also an all black screen has a shade of red not noticeable at any other time. Mind you it sounds bad but in general the color and picture are likable. I love the color on this set even after 9yrs any way today the unit died on me and when I went to try and power it up again nothing. I unplugged the unit waited a minute or two plugged it back in and the green lights lit on the PCB after a couple of seconds it powers off again. I don't know if all of these are separate issues or not but wanted to give an accurate portrayal.
  • ladywinn
    ladywinn Oct 12, 2010
    The ICs you need to replace have alot to do with Convergence and power supply Startup.
    CK zener diode if OK then replace the ICs.
  • imsureru Oct 13, 2010
    Any particular brand recommended on the ICs, and does it matter if they are specific to Hitachi.
  • ladywinn
    ladywinn Oct 13, 2010
    Use 120s or 150s they are better ICs .STK392-120 or STK392-150
    Ask Mats for Free Catalog they will send you one.
  • imsureru Oct 20, 2010
    I'm sorry it took so long but the zener diode was fine, getting ready to order the STK392-150's. Is there any thing else you can think of to check for!
  • ladywinn
    ladywinn Oct 20, 2010
    Replace the ICs and that should Fix TV.
Hitachi A/C. The green light of air filter indicator is on.
When its turn off, not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
Aug 10, 2012 | Hitachi RAS-09UH Air Conditioner
Not powering on ?
when i plug up my hitachi 61sbx59b proj. tv.
the green lights in the back come on ,a few seconds after them set tries to come up, you can hear the hv. for a fraction of a second then it shuts down.
Initially ceramic fuse was open but replacing it made no diference,r760 seems over heated,(dont know if connected).
GIL SCOTT
May 15, 2010 | Hitachi 61SBX59B 61" Rear Projection...
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Tv won't turn on.
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Oct 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 50UX26B
Good day, seanhanna;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Jul 12, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
My tv will not power up?
Hope this helps,
Mar 14, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 50ux58b
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitachi 61SBX59B 61" Rear Projection Television Logo
168 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
