Question about Oreck XL Ultra Bagged Upright Vacuum
My vacuum seems to be just pushing around things instead of sucking them up. I changed the bag and cleaned the bottom, but nothing helped.
  • 377 Answers
Did you check to see if the drive belt for the beater brush was broken or frozen up? The beater brush hits the carpeting and causes the dirt, etc, to jump into the air so the suction of the unit can pull it into the vacuum. The beater brush will be fairly easy to remove. Once it is out of the machine, clean it as best you can, add some WD40 on the plastic end pieces and when you reassemble, put a new drive belt on. This should solve the problem. Paul
Posted on Oct 11, 2010
  • pwillitz Oct 11, 2010
    I am sorry my solution was of no help to you.
    Paul
Why is my dyson dc54 blowing instead of sucking?
Congrats! See the comments for the solution.
Sep 13, 2016 | Dyson Vacuums
My 1 month old Oreck upright is not sucking in anymore. Worked fine for about 3 weeks. Now it just seems to push stuff around. I'm not sure if it is the bags? Ordered what I was told to order.
The intake tube could very well be clogged. Its pretty simple to disassemble. This happens commonly on Oreck, all you need is for something stiff to get lodged sideways in the tube then everything builds up around it.
Nov 28, 2015 | Oreck Vacuums
I know this is an old vacuum ,but I love it and up to yesterday it ran fantastic-it has quit sucking, yes i cleaned all hoses - nothing- clean bag -nothing yes the motor still comes on but will not ****...
I would guess its an upright type 7 bag or close, likely the drive belt is broken on the beater bar in the front or the vacuum impeller has broken loose of the motor if there is no suction.
Feb 27, 2011 | Vacuums
It seems to blow air out instead of sucking up
Remove the bag on top and the plate on the bottom. Clean out the air passages, top and bottom, looking for a clog. When it seems clear, turn on the vacuum to see if air is moving through. Don't allow a full bag to remain in place Check the brush on the bottom for string, hair, or thread caught in the bristles or bearings on either end. Hope this helps!
Mar 12, 2010 | Hoover Tempo Widepath Upright Vacuum -...
My bissell vacuum cleaner has stopped sucking things up as well as it was when I first purchased it two months ago. It also seems to be pushing more air out than it is sucking up.
with most vacuum cleaners the problem stems from carpet fuzz (especially in new carpet instalations) to build up of pet hair I have repaired several vacuum cleaners & my solution has use a shop vac if possible 15 amps or more clean the hose, check the belt(s) or if is not bagless make sure you have the proper fitting bag happy repair
Aug 23, 2009 | Vacuums
Not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Dec 06, 2008 | Dirt Devil Vacuums
Electrolux renaissance bag is light and vacuum stops and the change bag light comes on
Mine is doing the same thing, well it was. I sat it upright and it seems to be working fine... there is no blockage in the hose, the bag is clean... only thing I can't change is the filter. Maybe that is the problem, it doesn't seem really dirty though. I'm thinking perhaps the unit was too hot, hence having to be turned up right... makes it a little harder to move around but it is running at that is all I care. Hope this helps
Aug 29, 2008 | Electrolux Vacuums
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Oreck XL Ultra Bagged Upright Vacuum Logo
302 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
