Question about Whirlpool Gold Series GB2SHTXTS (219 cu ft) Refrigerator
We purchased our refrigerator new in Jan 09. Worked fine until today. Today I emptied the ice bucket into a cooler and reinstalled the ice bucket,holder/dispenser. It has been 6 hours and no ice has yet to be made. I even put it on Fast Ice for 2-3 hours and nothing. I checked to ensure it was reinstalled correctly and it was. Any suggestions why it is not making ice?
    President:
  • 1,891 Answers
Ck the elect eye the door may be covering the opening . also hold the lid on the left side in the closed pos and see if light on the right is solid. if blinking the sensor has failed. hope this helps mm
Posted on Oct 11, 2010
Why does the ice tray in my side by side American fidge freezer not re-fill with water?
You either have a bad ice maker or your water valve in the lower back of the unit is bad.
Jul 27, 2015 | Refrigerators
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
I cannot get the ice bucket out of the door. It has always been very difficult to remove unless it was just after I emptied the bucket and let it completely dry out before returning it to the door. I...
its just partially defrosted, ice chunks are up inside and through the unit, keep using the hair dryer,, also , once its defrosted completely, Look for a small leak , thats whats causing your problem in the first place
Jul 16, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Hi Localwonder We have a new Samsung Fr. Door Refrigerator RF4287HA.We got it in Jan. and it worked fine until June when the freezer slowly became warmer and warmer. Then the freezer died...
Check the motor of the refrigerator if the motor is functioning if isn't the motor is damaged or short circuit. Also check the prion if there's a leak if there is search for the place were the leak is coming.
Jul 01, 2011 | Refrigerators
We emptied ice bucket to fill cooler. Now all we get is crushed ice and not cubes. I can switch buttons from crushed to cubes but still get crushed. Did we do something wrong when I pulled out ice bucket...
There is a metal rod under the ice bucket. This rod sticks out from the back of the bucket. Where it inserts into the ice shelf, you will see a small square hole. This is what changes it from crushed to cubed. It is an actuator that moves the rod to allow cubes to come out. Stick a screwdriver into the square hole and move the actuator up and down. Then reinsert the ice-bucket and that should fix the problem. Hope this helps.
Mar 24, 2011 | Frigidaire FRS23H5AS Side by Side...
WILL NOT MAKE SWITCH FROM CUBE ICE TO CRUSHED I CE
remove bucket,empty into large bowel. inspect bucket opening,and be sure ther are no chunks of ice hindering movement of blade bypass mech. w/bucket out operate ice disp on crushed and cubed selections,listen for sharp snapping sound before motor turns.if sound is heard,reinstall bucket,and you should be good to go
Mar 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an Amana refrigerator #ABB1922. I purchased this in Jan. 09. Every so often it makes a loud cracking noise. Is this normal? I did have a problem today with things thawing in the freezer, but I think...
check to see if there is ice on the back of the freezer pannel. if there is then you need a new evap heating element.. this some times will casue cracking sounds
Aug 11, 2009 | Amana ABB1927DE Bottom Freezer...
Ice maker does not make ice
check water valve check for water
Apr 07, 2009 | KitchenAid Refrigerators
Ice maker problems
If the ice bucket is over filling there may be a problem with the ice maker as this should stop making ice when the bucket is full. The ice in the bucket can freeze together just due to the weight of ice cubes . I suggest you check the ice within the bucket is all broken up and not frozen into big lumps
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gold Series GB2SHTXTS (219 cu ft) Refrigerator Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
