Question about Sennheiser EH150 Consumer Headphones
I cant hear out of the right headphone, when i jiggle the wire i can sometimes get sound out of it. idk how to fix it, and idk if i can get it replaced, ive had it for less than a year.
  • Sennheiser Master
  • 5,126 Answers
Check out my Tip on dealing with dodgy cables/plugs on headphones.
Posted on Oct 12, 2010
Why is there no sound even in bypass mode?
The bypass switch developes dry joints after some time. The earpad has to be removed and the speaker plate unscrewed and lifted back. The cct board connected to the switch will now be exposed so the switch legs can now be resoldered. Reassemble and you should be good to go.
Apr 28, 2014 | Sennheiser PXC 450 Headphones
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
I found some pretty cool earphones... they are puregears purebeats headphones set. When I found them, the right earbud wouldn't make a sound unless I jiggled the wire by the speaker. And the left one...
The thin wire used in the leads breaks internally and there is no easy way to fix them, you could try to fit another cable to them but it is usually not very successful. Replacement is about the only option.
Mar 02, 2012 | Audio Players & Recorders
Bose on ear headphones
replace the jack,
cut the wire from the jack then replace it with new one.
remember that the
Tip - Left
Ring - Right
Sleeve - Ground
Jan 11, 2010 | Bose TriPort Consumer Headphones
Sound in left earbud shorts in and out
If its not hard to open the case, just solder the connection again (only if you found out that the problem is inside).
Also check the wire if it have 100% connection. You may also check skin of the wire. If found out no good, so possibly this could fix the problem.
Mar 02, 2009 | Etymotic Research Isolator ER-6i Consumer...
Only hearing sound out of left side of headphones
i think the problem is in the jack of your sound blaster. since you have already tried different headphones and the problem still persist, and when you use speakers it works fine. i conclude it is the jack of your sound blaster card.
Dec 22, 2008 | Creative Labs Sound Blaster Live! 5.1...
Headphone Speaker Jack Needs Replacement
That honestly sounds more like a headphone wire problem than anything else. If you have another headset, headphones or speaker system that you can hook up, I would test it on those to try to rule that out as a problem.
If that isnt it, I can try to find the disassembly instructions for your laptop. (Unless your warranty is still good, in which case I would tell you to send it in and get it fixed professionally.)
May 16, 2008 | HP Pavilion ze4125 Notebook
Sennheiser EH150 Consumer Headphones Logo
264 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
