Tried it but nothing....
Can't be the monitor cos I was using it just earlier... I think this board only has one AGP slot?? what shall I try now?
    Scholar:
  • 187 Answers
Do you have a second PCI graphics card you can try?
Posted on May 31, 2008
How to add second monitor on ECS RS482-M
Doesn't work that way Max.
You can use EITHER the OnBoard Graphics,
OR;
the Add-On Card graphics. (Graphics card)
BIOS will NOT support both at the same time.
If you wish to use dual monitors, get an AGP card that has more than one graphics port on it.
For example, although I'm using a graphics card based on the PCI Express technology, and not AGP technology; my card has a VGA port, DVI port, and HDMI port.
1) VGA Connector; http://en.wikipedia.org/wiki/VGA_Connector
http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
2) DVI; http://en.wikipedia.org/wiki/Digital_Visual_Interface
http://en.wikipedia.org/wiki/File:Dvi-cable.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface#Connector
3) HDMI; http://en.wikipedia.org/wiki/HDMI
I use the VGA port, and the DVI port.
RCA EN-V L26HD31, (26 inch HDTV) to the VGA port.
HP 2009M 20 inch Widescreen monitor to the DVI port.
Had to install drivers for HP 2009M.
Let's say I had two DVI ports on the graphics card.
(ATI Radeon HD5450 is the graphics card I have)
But I have a monitor with a VGA cable, and a monitor with a DVI cable.
I would (And have) use a VGA to DVI Adapter.
One example,
http://www.directron.com/dvi.html
Note that the DVI is Male, and the VGA is Female.
The graphics card DVI connector is Female.
The VGA Cable connector is Male.
So.............what is the manufacturer name, and model number of the graphics card; plus what type of monitors are you trying to use?
That is, what type of monitor cables do they have?
Know this;
My HDTV I'm using as a monitor is Digital. However I'm using a VGA cable on it. Best quality would be achieved if I got off my lazy rear, and attached a DVI Cable to it. It uses both.
VGA is Analog. A computer however puts out a digital video signal.
The computer has to convert the digital video signal to an Analog one. This slows the video signal down, and the quality is not as good.
Best to use a digital monitor. (Or a digital monitor WITH a digital cable. DVI Cable. Such as I need to do)
You are also using a PCI Express graphics card, NOT an AGP graphics card.
I'm wrong? OK.
In the meantime turn the computer off, unplug from power, and yank that AGP card out of the slot you put it in.
Tell me what expansion slot on the motherboard you put it in.
The Orange expansion slot on the motherboard, is a PCI-Express x16 slot. Uses a PCI Express graphics card -> ONLY
The white expansions slots are PCI.
Can use a PCI graphics card. CANNOT use an AGP graphics card.
Post back in a Comment.
Regards,
joecoolvette
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131338
Feb 18, 2013 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
Asus P4T533-c motherboard fans hard drive everything turns on and fires up but no picture on monitor tried many video cards everything is set right tried in the case out of the case still nothing any ideas
This MB is designed for a 1.5V AGP 2.0 video card. The card slot is keyed to prevent installation of an incompatible board, but there were some older AGP 1.0 cards that use 3.3V that had dual key slots and could be inadvertently installed in the AGP 2.0 slot. If this happens you will damage the MB. Only you can check to see if ths may have been what happened as you say you had tried many Video Cards.
Jan 07, 2012 | ASUS Computers & Internet
Do i have a slot (agp slot?) on my gt5620 computer? Iam trying to install a ati graphics card
Your computer is too resent to have an AGP port. They used that on earlier generation.
What you have on your board is a PCI Express x16 to add a more powerfull graphic card it will be the longest port usually the first on top.
Beware that on computer like those make shure that the power supply can take the load of the new graphic card.
Oct 29, 2010 | Gateway Computers & Internet
Inserting GeFroce fx 5200 graphics card!
sorry to say this your dell system only has a X1 vga slot it is not compatible with the card you have.
If you want to use a card you have to go for a new system
Nov 30, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
I have an HP Pavilion a1777c with a blank monitor
If the computer is starts up normally other than the no-video problem (that is, you hear all the normal sounds from the computer and the usual Windows startup music), then you probably do need a new video card. According to HP's spec page for the motherboard used, you'll need a PCI-E video card. Don't confuse this with a regular PCI card which has a different connector.
The spec page also says the board has integrated graphics. so you could remove any video card that's been installed and try booting with the built-in video. If everything else is working properly you can use that until you get a new expansion video card.
If the trouble is that the computer's not booting at all even though it's coming on, you'll need to figure out why. This might be a memory or video problem, although these usually cause some beep code if the motherboard gets into its POST (power on self-test). If nothing at all happens, this is often the sign of a bad power supply, processor chip or system board.
Jun 16, 2009 | HP Computers & Internet
I want to upgrade my graphic card
That video card won't work on your system board. The video card requires a PCI-E expansion slot, but the system board has an AGP slot. You'll need to look for an AGP video card. I tried looking on the site you gave for the card you were considering and they don't seem to have any AGP type cards, so you will need to shop around some more.
Nov 19, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Mother board asus A7V8X-LA
then that video adapter IC (integrated circuit ) in the motherboard which is located near the AGP or PCI express slot is in problem just visit the motherboard technician & get replaced that one ..
it will work ...
the cost of it is some what higher i think to repair .....
just once you visit the motherboard technician before you purchase the new board ....
Jul 04, 2008 | Computers & Internet
No video
ok fine i think there exists some problem in the cable connecting from the CPU to the monitor just try removing that & inserting it again ....
if the same problem persists then there may be some problem in the port of the video card just take tester & test is there power supply or not ....
if there is no power supply then some of the capacitor on the video card might have burned out due to this ports will not be working ....
if there is power supply then there will be one IC(integrated circuit ) on the motherboard just near by the AGP or PCI express slot (i think in your motherboard there are 3 IC s near there)
in those 3 IC s if some IC goes means also you will not get the display ...
(the video must be inserted to the PCI express slot or AGP slot only) you must not insert it on PCI slots ...
you make a difference of PCI or AGP slot as this will be only 1 or 2 on every motherboard & it will be smaller in size than the PCI slots & there will be colour difference(may be the PCI slots will be white colour & AGP or PCI express slot in black or brown colour it depends on the motherboard)
check on which slot you have inserted it & insert it correctly if you inserted in some other slots ...
remove the video & insert it again & try check the cables the cable may be loose contact ...
any doubts you can reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Jul 03, 2008 | Computers & Internet
Nothing on screen, fan running on processor, hard drive trying to load OS
Hi Eagleboy, I wouldn't suggest buying a board on ebay. If things do not work out you'll spend more for shipping to & back just returning it rather than buying a new AGP4x video card.
You can double check the AGP slot. Get a strong flashlight. Look down into the slot, check for bent copper retainers, dirt & dust. You can also check & make sure the retainers almost touch each other from their oppsite sides. This is where you can help the AGP card get a tight fit. Clean both the AGP cards copper contacts & the slots copper retainers. Use house hold alcohol & some cotton swabs. Blow out the slot well
I'm guessing that you set the bios up correctly when you were using the AGP card & reset the bios when you went back to using the MB's VIA UniChrome Graphics. I agree with you, no need for a new PSU or HD. Shame you can not test your AGP card in another PC. If you can't do that than buy another AGP4x card & install it. http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=879&Nav=|c:318|c:694|&Sort=0&Recs=10
This is all a suggestion. If you feel the board is bad & replacing it sits well with you. (Do what you think is best).
Here are some compatable boards I have come across. I am unaware what CPU you are using.
http://shopping.yahoo.com/p:ASUS%20P4T533%20Motherboard:1990997820
http://www.pcupgrade.co.uk/productdetails.asp?ProductID=3576&categoryid=261
http://www.google.com/products?hl=en&resnum=0&q=motherboards+socket+462&um=1&ie=UTF-8
Good Luck!
If there is anything else I can do, just ask.
Mike
Mar 28, 2008 | Asrock K7VM4 Motherboard
Monitor internal card
Try a different PCI slot unless it is a specific AGP board or specific video slot on the motherboard, maybe the slots blown.
You can try reseting the video ram incase the drivers have become corrupt, you would need to research how to do that on the net as its different per machine which keys to hold down on restart.
Failing this try a different video card !
Jan 08, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
383 people viewed this question
David Payne
David Payne
