Question about Dell RADEON X600, (128 MB) Graphic Card
Call Of Duty 4, Need SERIOUS help!!!!!!
I have thsi graphics card on my DELL dimension 5150 and i want to play COD 4 without any problems.
I bought the game the other day and had a few hours good online playing until my screen turned blue.
It says that the ATI graphics driver caused it but when i download the newest updates the online game lags so much so i cant play it.
Do you have a fix to stop my screen turning blue or a fix so that i can download a driver that doen't make the game lag or go slow.
Thank you for your help
  • flyert Nov 26, 2008
    I don't get the blue screen, but I do have the same driver and 1 GB of RAM. The problem I have is everytime I start the the game the resolution expands to where I can hear it but can't see it because I figure it's too big. I tried too adjust my screen on my desktop but the game still responds in the same manner. Any suggestions for my current setup? Thanks in advance.
  • 49 Answers
Hmmm. The blue screen isnt a good think. Even though people say what kind of model a dell computer is, doesnt describe the processor, memmory modules...how much...speed etc.
You need to uninstall your graphics drivers.
Download ccleaner and drivercleaner. Do a scan with both. Do a full driver clean with driver cleaner because it clears the junk out of your registry. Make sure you do a reg backup with both programs.
Now you can restart your computer and install the latest drivers.
the x600 card is a little on the outdated side and can probly run the game on low to medium. Start with 800x600 resolution and turn aniostropic and antiliasing off. Turn everything off that you think is necessary, start the game, and see how it runs. Download fraps so you can see your fps. If you get about 60 than you can turn a setting up. If you get 30 or lower, turn your settings down.
I hope this helps. Please contact me if you need any further advies. I also want to say that you should have at least a gig of memroy and hopefully 2 gigs to play the game at good settings.
Posted on Jun 01, 2008
Video chip location on computer board
If this is a direct reference to the Dell Dimension 5150 Desktop computer, it is an Intel GMA950 integrated graphics chip, soldered to the motherboard.
You will see Intel at the top of the chip, and GMA950 under Intel.
This is Dell Support, and the Service Manual for the Dell Dimension 5150/E510 Desktop computer.
More specifically this is the Specifications Documentation, and the Technical Overview part of the Service Manual,
http://support.dell.com/support/edocs/systems/dim5150/en/sm/techov1.htm#wp1058472
I referenced this page, to show you the basic components on the motherboard. Click on the sub-heading - System Board Components, in the list.
At the top of the motherboard you will see the processor sitting diagonally.
Under it you will see the Northbridge chipset, and more specifically in this crude illustration, you are looking at the heatsink which resides on the Northbridge chipset.
(Has a Z shaped clip which holds the heatsink to the Northbridge chipset. The heatsink has a 'meat cleaver' type of design)
In the area that is blank to the Left of the Battery, will be the Intel GMA950 GPU.
(GPU = Graphics Processing Unit, or graphics chip)
If you are wanting to upgrade your graphics quality, purchase a graphics card, and install it in the PCI Express x16 slot.
{In the illustration the slot is over to the Left.
PCI Express x16 connector (Slot 1)
How to know what graphics card is compatible with your computer?
1.You have a PCI Express x16 slot for a graphics card. This is the style of graphics card you need.
It is the PCI Express 1.1 version technology used. I wanted to add this in case you need it for reference.
Be aware of this! No matter what anyone tells you, you can use a PCI Express graphics card based on the PCI Express 2.0 technology, in your PCI Express 1.1 slot.
Why?
Because PCI Express 2.0 technology is Backwards Compatible with PCI Express 1.1 technology.
Backwards Compatible. Means it will recognize the PCI Express graphics card utilizing PCI-E 2.0, and will work.
2.You have a 305 Watt power supply. You need to have enough Wattage, (Power), for the computer system, and the graphics card.
I advise using an ATI Radeon graphics card. Which one? Since you have a Pentium 4 processor, 305 Watt power supply,
(With all probability a 18 Amp, 12 volt power rail),
I suggest something along the lines of an ATI Radeon HD3850.
Depends on what you expect from your graphics.
If your reference in your query above is that you believe your graphics chip may be burned out, then I definitely suggest using a graphics card.
The PCI Express x16 slot is controlled by the Northbridge chipset. Doesn't matter if your Integrated Intel GMA950 GPU is burned out, or not.
Oct 12, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
PC was rebooting itself. I tried vacuuming out dust from inside box. Now it won't boot up at all. Numbers on front panel 3 & 4 stay lit and monitor only shows scrambled colours PC is a DELL Dimension...
Try manual cleaning the graphics card and the RAM by removing from the slot and rub the pins with pencil eraser as shown in the images.
And re-attach them to the motherboard, also clean the graphics card's fan with small paint brush. Works for me, hope same goes with you.
Sep 24, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150
This high end video card that you just upgrade to requires a high power supply , so this can really be a power supply issue so trying a high power supply will be a good thing to do...
Aug 17, 2009 | Computers & Internet
Geforce 8600GT gaming problem.
whats power supple do you have? i have a 8500gt and it needs at least a a 350 watt most of those dells have a 305 watt upgrade to a bigger supple hope this helps
Feb 07, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 won't start
See solution in http://www.fixya.com/support/t1372311-start_up_fault
Dec 20, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimesion 5150 graphics card
Have you tried to install the card in the slot only,and not use the power supply. It may not need the extra power.
May 31, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
150 people viewed this question
Alun Cox
