Question about HP Computers & Internet
Beep codes 1long and 2 short with blank screen
    President:
  • 2,340 Answers
Usually Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
You could try removing the video card and re-seating it. Also you may try using a another power connector than the one you are using as one of them may have a problem. But it looks like a video problem. Check BIOS in case your settings changed and the onboard video (if present) is on. In certain Mainboard it could be a memory issue, reseat your RAM too.
Hope it helps.
Posted on Oct 11, 2010
1long beep 2 short beeps on laptop when turning on black screen
login to the computer manufacture with make and model , request latest driver.
Nov 19, 2016 | Computers & Internet
My computer is beeping every so often it beeps about 3 times and it does it fast please tell me why
It only mens that there's an error on your computer.
Beep codes are use to check or identify which computer part/s causing the problem.
Beeps
Error Message
Description
1long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1long, 3short No video card or bad video RAM Reseat or replace the video card. High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow. Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
May 11, 2011 | Toshiba Computers & Internet
Satellite x205-sli1 will not boot black screen error beep 1long 2 short please help. Powers up good and reseated ram nothing.
Thank you for sharing the beep code. It means that its a problem with the Video Card and Video Cards are usually buit-in to the Motherboard for laptops. The only way to fix it to replace the Motherboard in order to get the new Video Card. Hope I've helped you somehow.
AnEspera
Apr 24, 2011 | Toshiba Satellite M65-S809 Notebook
Hi my system will not power up, i get one long beep then two short ones
there's a issue with your ram.
try and put one stick at a time and see if it works.
Mar 06, 2011 | ASUS P5VD2-MX SE Motherboard
Post beeps long short short on power up, no display, beep pattern repeats until power turned off. this is after installing this motherboard. Rams are KVR533D2n4/1G Kingston. Isthere somewhere I can find...
1long and 2 short is a video adapter failure, replace the video card and see if the problem goes away, unfortunately if the beeping continues with other video cards, then there a faul on the mainboard.
1 long and 2 short is very common and well known fault in both desktop and laptop computers.
Feb 06, 2011 | ASUS P4B266 Motherboard
My acer computer wont turn on it just beeps about every 5 seconds.
Those are beep codes-- for a hardware issue- I need to know the BIOS manufacturer and the exact code of the beeps--1-1-2 or 1long-2 short etc----also be sure all chips are seated correctly and nothing has changed since it last worked
Jan 18, 2011 | Acer Aspire One AOA150-1784 Netbook
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Gateway c140 beeps
If you have an AMI bios (you can tell when you boot and the black screen has writing on it at startup - the bios type and version is the first thing at the top of the screen)
1 long and 3 short beeps indicates that the memory is not seated properly. You should check that it is secure on your motherboard. If it is seated securely, your memory is maybe faulty.
Mar 21, 2008 | Computers & Internet
Computers & Internet Logo
184 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
