Question about First Years The Gentle Vibrations Crib Soother
Lost the manual... how do I open it to put in the batteries??? Thanks! :)
Have lost manual and don't know how they work, Thanks
google
make model manual
or check manufacturers website
Feb 18, 2016 | Health & Beauty
Forgot password need new one
pull all cables
open the case
find the battery
take it out
shortcut the two contacts in the battery compartment. Its 1,2 volt so you will not die, nor will the pc
put the battery back in with the flat side containing the charactes up
fire your PC up. You will ahve to put the date again.
the bios pass is gone
if you have lost the pass on the windows you have to reinstall the windows or put a call in for dial in
thanks
rene
pls add kuddo's if i helped you
May 27, 2011 | Dell Studio 15 Laptop
My chamberlan garage door opener keeps beeping
The only thing on a chamberlain garage door opener that can beep is the battery back up unit. It beeps if it is being used or if it has lost it's charge or if it has lost the power to be charged. There is also an led light that will give you information on the status up by the battery too. These will be in your manual to decipher. You can get a new battery at chamberlain.com Thanks BB
Aug 21, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Changed battery and lost program cant find manual need reprogram 4 number code
changed the battery and lost the manual, put my code in and it worked , latter it started to beep and now it doesn't work... respond at all ....help thanks
Apr 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Password lost ,clear the Bios
this would and could be done by shorting out the bios pin or taking out the battery inside or pay $65 bucks to have a locaL tech do it for you simply put the device needs to be opened up a tech would have a device to reset it without opening the unit of course your ownership will need to be proved at that point not saying you ripped of a poor kid or anything but just putting that out there :) thanks have a happy new year and please rate your fixya experience!
Dec 30, 2009 | Acer TravelMate 245XC (LX.T3006.069) PC...
How to put it n phone lock, we have lost the
Go to main menu, then choose settings, then choose securiy, then choose sim lock or phone lock, the default security code is 1234 or 12345
Nov 05, 2009 | Nokia 1650 Cell Phone
Top on clk430 wont go up or down
Disconnect the battery and leave for a few hours before reconecting.This should reset the switch.
Jul 24, 2009 | 2003 Mercedes-Benz CLK-Class
Battery
Using screwdriver open up remote, tape battery securely, make sure remote works and put it back together. You can also buy a universal remote to control it.
Oct 03, 2008 | Cyberhome CH-DVD 300 DVD Player
First Years The Gentle Vibrations Crib Soother Logo
106 people viewed this question
Top First Years Toys Experts
Andrew Taylor
Andrew Taylor
Are you a First Years Toy Expert? Answer questions, earn points and help others
