Question about Refrigerators
My refrigerator sounds like its sizzling - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
That is the compressor trying to start and not getting started...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 11, 2010
The freezer is not getting cold and the water is dripping down the back onto the coils and it is causing a sizzling sound and smells like it is burnt. How do we fix.
Turn it off before you burn your hose down. Nothing should be so hot as to make a sizzling sound! There shouldn't be any water on the outside of the unit. It sounds like there is leak.
If this unit has been in operation for a while, like a couple years and longer -- the coil that is under the unit is most likely completely matted up with dust. This needs to be cleaned. With the unit off use a vacuum cleaner, brushes -- any way you can devise to get rid of all the accumulated dust.
Because I can not think of what water could be dripping on to make a sizzling sound - or where that water be coming from - I'm going to suggest you call in a professional on this one.
There shouldn't be any condensate that can drip on anything. The clogged up coils underneath could cause the freezer not to cool properly.
A burnt smell sounds like electrical - and that's why I'm concerned.
Don
Mar 24, 2012 | Maytag MSD2756G Side by Side Refrigerator
I have a ge side by side refrigerator/freezer and i'm hearing a sizzling sound from the freezer side. Sounds like water is hitting the heating element causing a sizzling noise. Should I empty th
If you are sure the sound is coming from the freezer side, then yes you should empty the frrezer and take off the rear shield. While the heating element is normally encased in glass or plastic. Water droplets hitting an electrical connection could also cause a sizzling sound.
Feb 03, 2012 | GE Refrigerators
I opened my freezer (arctica) and heard a sizzling sound -- i could see coils behind the grates on the back wall of the freezer that were bright red (like an electric stove coil on high) -- the water was...
I hope you unplugged your unit or tripped the breaker. If they are bright red then you have an electrical short that should have tripped the breaker a long time before they turned red hot.
Jul 15, 2011 | GE Profile Arctica Stainless Steel Top...
Side by side refrigerator is making a sizzling noise at the back bottom of the freezer
The sizzling in your case means that it is working....it is just water dripping from the cooling coil onto the hot element that defrosts it...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jan 18, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator stoped cooling and freezing. The lights and the fan come on, but will not cool...
The first thing I would do is remove the cover on the back of the fridge and check if the compressor is running. If it's not, then it could be the start device. Remove the power from the fridge, pull out the start device from the compressor and shake it. If you can hear something inside is moving, replace the start device.but if otherwise then,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Good luck and hope this will work
Jul 30, 2010 | Maytag Refrigerators
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Jul 20, 2010 | Whirlpool Refrigerators
My side-by-side refrigerator freezer, the coils in freezer ice up, and the refrigerator section get's warm. What is the problem?
OK'Lets start with the defrost timer located below refrigerator and front kick plate. Turn timer until it cklick into a position that stops fans and compressor. Leave like this for about 30 minutes. Listen inside the freezer for sounds od sizzling or crackling sounds the sounds of defrost. If timer does not automactically come ou of defrost turns gently again clockwise until the compressor starts. Let me know what you find, Sea Breeze
Feb 21, 2010 | Refrigerators
Sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Sep 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Orange light in the lower part of freezer
pants, don't worry about this, your refer was going into defrost. When this happens, the defrost heater turns on to melt the ice off the evaporator in the freezer comp. Last's about 20 minutes and sometimes you can see the glow and hear the ice hitting the heater...Catriver.
Jan 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
