Question about Electrolux 23 in. ESL6114 Built-in Dishwasher
Water in bottom after running. Dows not drain properly
  • Electrolux Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Oct 11, 2010
Samsung new dishwasher will not run through a cycle or drain properly. Water left in bottom. Keeps stopping and going to quick flashing.
The drain hose from the dishwasher may be partially or fully clogged with food stuffs like peas, corn, green beans, or other foods. disconnect the drain hose and clear debris from drain hose and run threw drain cycle.
Mar 16, 2013 | Dishwashers
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
My fridge keeps filling up with water, I pulled the bottom of the fridge out and vacumed, the tray underneath is dry and I guess the fridge isn't draining properly. How do I fix this?
Yes you are correct it is not drainind properly.
Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Apr 12, 2010 | Kenmore 64802 Top Freezer Refrigerator
WD1000 has too much water
You are not hooked up to the drain properly. If you do not create a trap the water will drain back into the machine. The drain tube goes from the bottom of the machine up to the top and then back to the bottom. You need to run the drain tube up to a final drain or other trap. You can even create another mini trap by making a loop before running into the drain. Whatever you do just try to get the hose to go about as high as the highest point at the back of the machine, but not higher, as it will create a siphon and flood the machine.
Jan 24, 2010 | Malber WD1000 Front Load Washer/Dryer
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Water left in the units top & bottom
From what you describe, the drain hoses are not properly connected.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Feb 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Sep 12, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Ice forming in bottom of freezer
Rita, your drain hole is frozen over and when your refer goes into defrost the water is running out into the cabinet instead of down the drain hole. Remove the evaporator cover and poor some boiling water in the evaporator drip pan. This should melt the ice and clear the drain hole....Catriver...post back.
Aug 16, 2006 | Frigidaire FRS26KF5C Side by Side...
Electrolux 23 in. ESL6114 Built-in Dishwasher Logo
319 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
