My printer will no longer feed paper. - Office Equipment & Supplies
  • sarahayton Jun 01, 2008
    Sorry. It's a Canon Pixma MP150. For a while it only fed paper very crookedly and crumpled pages as it printed, but now doesn't feed paper through to print at all. The only error message that appears is that it is out of paper.
  • 51 Answers
Not enough information! Need printer make and model, any error messages etc
Posted on Jun 01, 2008
  • Fred Fisher Jun 01, 2008
    Ah - I really only deal with HPs but I'll have a go. It sounds liek something has got lodge in the feed mechanism somewhere.
    Does it try to feed paper, ie make the correct sounds as the rollers turn,? If you take the piece of paper out that it has tried to feed, are there any markings on the front edge where it might have caught against something on its path? Is the problem with both paper trays, bottom and top?
Not feeding the paper
inside the printer has to be a roll that takes the paper and get's it into the printer try to wipe that roll with some technical alcohol, i hope this helps you.
Jun 17, 2009 | Samsung SCX 4521F All-In-One Laser Printer
No longer feeds the paper correctly when trying to print. It seems to feed the paper at an angle. I can hand feed one page at a time but still isn't straight. What can I do?
Please try to reinstall the your printer driver. Usually the driver is the one which malfunctions.
Good luck.
~regards,
Jegan
Jun 03, 2009 | Dell Office Equipment & Supplies
Paper jams no matter what stock I use; Lexmark e232
Slipping paper feed rollers is probably causing the jamming. Remove the paper tray and tip the machine back so that you can access the feed rollers from underneath. A good technique to isolate this problem is to remove the rubber feed tires, turn them inside-out and refit them. If it now works OK you need to get new feed rollers.
Jun 01, 2009 | Lexmark E232 Laser Printer
Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
Jan 29, 2009 | Epson Stylus CX3800 Printer
My printer no longer feeds in Epson Premium Glossy paper S041624
Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
Regards,  raj_p5983
Jan 20, 2009 | Epson Stylus Color 1160 InkJet Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Printer problem
Sometimesa feed roller can become smooth and it no longer grabs the paper.
If you ahve some emery cloth try to rub it gently on all rollers to roughen them up a bit.
Jul 05, 2008 | Canon PIXMA iP1600 Printer
No longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Apr 01, 2008 | Brother HL-5240 Laser Printer
144 people viewed this question
jasbo
jasbo
