Question about Brother LS-2125 Mechanical Sewing Machine
Why dose the thred keep breaking even when im useing heavy dudy thred
  • Brother Master
  • 7,365 Answers
Try rethreading the machine
the thread tenison may be to tight
the needle could be damaged
needle & thread may not be compatable--here's how to tell
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Oct 11, 2010
Top thread keeps breaking. Adjusting the tension does absolutely nothing. It seems as though the thread is getting caught on something inside the machine between the thread guide and thread take-up lever....
these are suggestion, if they don't help then the machine needs to be checked at a sewing machine shop
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 27, 2013 | Euro-Pro Sewing Machines
I have been sewing denim, and the top thread keeps breaking at the needle. What adjustments do I need to make. It also bunches from the bobbin.
Are you trying to use a heavy thread like buttonhole twist through the needle like the yellow thread on store bought jeans? Most domestic machines will not cope with this heavy thread and it will be too large for the eye of the needle too.
If you are using regular weight 50 polyester thread and its breaking then it could be because the top tension is too tight. Just loosen off 1/2 a number on top tension dial and see if this helps.
If possible, buy a pack of jeans needles size 100 too, these are blue coated with teflon I think, and makes it easier to slip through denim which is a very dense fabric.
Hemming denim jeans is probably one of the toughest jobs for a domestic sewing machine so if you are trying to do this, its a good idea to take it slowly and use a "humpjumper" which helps to maneouvre over the thick side seams.
However, even with all the above, many machines won't sew more than one layer of heavy dense weave denim.
Jul 20, 2011 | New Home HF-106
The needle dose not catch the thred at the bottom
Try a new needle inserted flat side away from you. If that doesn't work, it may be your timing messed up. I hope it is just the needle for you. Good luck
Mar 06, 2011 | Sewing Machines
Thread keeps breaking
Tention and wrong thred, also use jersey ball point needles 80/12 wcbotha@yahoo.com
May 12, 2010 | Tacsew 950
The thread is loaded into the bobbin however it keeps looping around the thing that the bobbin sits on.
On bobbin holder is a small screww to set the bobbin tention, must be set (tighten) if too loose it will glog up if too tight it will break the thred. wcbotha@yahoo.com
May 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
My thread keeps breaking. I got this machine
Thred breaking is one of the following: tention to tight, wrong thred, wrong needles - use jersey baal point 80/12 needles for all material and thred, bobbin tention too tight. wcbotha@yahoo.com
May 10, 2010 | Sewing Machines
When I sew the back of the material thread is big loops. Is this because my bobbin is not set right?
well errr???? im a man talking to you !!!! how would i know whats wrong here???? i cant stich a button on???? but ???? me thinks its not so much the bobbin thats not set right its the needle thred tensions that are wrong there far to slack, whats happening is the needle is stiching but the bobbin is not pulling up all the exess slack, you have missed threded the sewing machine? missing out the thred tenshion bit,,that or it's just not tight,,, crank it up tighter and see if this helps pull it up more under the stiching ? if im wrong slap me !
Oct 24, 2009 | Singer Sewing Machines
Thred keeps braking
It might be tension to tight, threaded wrong or the bobin isn't thread the right way.
Apr 17, 2009 | Kenmore 15208 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
