Question about Maytag Dryers
Maytag centennial dryer - timer dial does not move - dryer is heating
You most likely have to replace the POS timer, my girlfriend\'s failed out of the box, a month later and again two years later. I dissected the timer and found the cheapest set of plastic reduction gears between the timer motor and the gear that drives the knob, and one of them had the teeth stripped off.
You can find them on ebay for less than $50 shipped rather than pay $100+ for one from a parts store.
Posted on Dec 09, 2012
  • 27 Answers
SOURCE: Electric Dryer problem
the timer has a small motor to advance the timer. the motor is the likely problem. on some old maytags you can get just the motor, but you probably will have to replace the complete timer. hope this helps.
Posted on Nov 02, 2007
TheMobilian
  • 8220 Answers
SOURCE: Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
Posted on Apr 10, 2009
SOURCE: Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Posted on Jul 13, 2008
roniecon
  • 6927 Answers
SOURCE: Whirlpool dryer WED5300VW0 runs and heats but
The timer has gone out,replace the timer with a new one.
Posted on Oct 10, 2009
Testimonial: "Thanks"
smartr10U
  • 1305 Answers
SOURCE: maytag centennial commercial technology motor will not run
Sounds like the door contact switch is stuck in the on position.
You can replace the switch pretty easily.
Turn off the power, and with a phillips stubby screwdriver, remove the two screws in the front kick panel of the front panel and tip the bottom edge out. There are two metal retainer clips on the top edge of the front panel and as you tip the panel, the top retainers will disengage. There are 2 wires on the front panel to the door switch that are easily popped off and the switch will pop out of the front panel with minimal effort. I'm sure you can find a door switch for this online at repairclinic.com
Posted on Jun 08, 2010
Testimonial: "thanks someone was telling me timer switch was bad thanks for giving me another avenue to check"
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Why is my timer not counting down, and no heat?
Make sure the vent and heater air intake are not clogged with lint. Also, check the gas pilot to make sure it is not blocked up with gas line sediment, and the ignitor is working properly. The timer is probably waiting for a signal from the flame sensor.
May 08, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag centennial dryer wont heat up
I was working on a dryer similar with a no heat problem and made a video you might be interested in:
Dec 21, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer heats OK when turned on but the timer never moves and the dryer doesn't turn itself off......
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./,./'
Jul 13, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer Tunrs on and runs with no heat and timer never moves
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Amana Gas CLothes Dryer Mod#NDG7800AWW dryer will heat and does dry some but when it moves to the less dry the dial does not move and the dryer does not heat
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
Oct 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Oct 25, 2007 | Dryers
Dryers Logo
909 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
