Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I recently installed a new Badger 5 garbage disposal in the kitchen sink. I has worked great, but a few days ago it started making a horrible sound when it is turned on. I sounds like there is a spoon or something in there, but it is completely clean and there is nothing there. Any ideas on what this could be? Maybe a blade loose or something?
  • 4,340 Answers
Likelyhood of loose blade is very low, but not impossible.
Get a good light and a small mirror, something is jammed inside, I bet. Often a piece of somthing gets lodged in a dischaged port and the blade hits it evey rotation.
Posted on Oct 11, 2010
Insinkerator badger 5 troubleshooting
Use vacuum cleaner to clean out anything:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If noise continues, use phone to record sound, buy another unit and attach new disposal to same mounting bracket and then return defect in new box for refund.
Jul 04, 2013 | Home
Is there a way to bypass the disposal to be able to use the sink w/o the water dripping from the bottom of the Badger 5 disposal?
If disposal is leaking, it has to be removed before it damages cabinet and causes mildew.
Then install a different strainer basket if you want to connect tubular drain.
Tubular sink basket
http://media.rd.com/rd/images/rdc/family-handyman/2001/11/Kitchen-Sink-Basket-Strainer-af.jpg
Disposal sink basket:
http://0.tqn.com/d/homerepair/1/0/m/0/-/-/sink_flange_noted.jpg
You can also buy same brand and size disposal and install without changing sink basket.
I wrote ez disposal replacement steps that show disposal removal and tips for connecting tubular drain.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 27, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have installed a garbage disposal under my sink (Badger 5). It is not new, about 2 years old. Brought it from my old house. It worked great before moving it. I wired it in myself. It works when turned...
Smoking electrical device is probably not good news. It implies electrical short.
Freely spinning cutter disk means the sealed motor bearing did not rust out and bind the motor.
Smoking disposal means minimum of melted insulation and overheated motor.
Overheated motors will slow down and stop working.
What caused it? Maybe moving disposal around loosened something.
Decades ago household items were taken to the electric shop and they rewound the motor.
Today metal and copper is landfilled or scrapped to other parts of the world.
I wrote ez disposal replacement steps from when I worked apartment maintenance, but you are experienced already.
Jul 24, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage dispoal not working. The blades spin freely inside, the reset button has been reset, when you switch it on the moter makes a faint humming sound, and the allen wrench will not rotate either way.
You need a new disposal.
Free-rotating blades show there is no obstruction.
Humming says you have power.
Frozen allen wrench says bearings are rusted.
Motor is now overheating each timer electricity is turned on, and motor will overheat and stop humming.
At least the drain is clean and water is not flooding under the sink, which means you can continue using sink until disposal is replaced.
I wrote tips for installing disposal from days when I worked apartment maintenance:
Feb 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 plus in sink erator is not working
Here is a tip the I wrote that may help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammedheatman101
Sep 04, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Garbage disposal doesn't empty
To me it sounds like the waste pipe is clogged
Try a plunger
Kurt
Mar 19, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Badger 5 EX 3/4 Hp In sink Erator
the disposal is attache to the button of th sink by means of ring and clamps.
take a look how th ekitchen sink is mounted. the disposal is mounted the same way. you may need to get new rubber seal and a new plate for the buttom, where the screws is. you can take the ring to the near home center of plumbing store, and get a replacement.
you can use "plumber's putty", or " goop" .thing else will keep the water out.
Nov 05, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
414 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
