Question about Linksys Wireless-G WRT54GS Router (e125894)
Hard Wired Port Problem
The hard wired ports stopped working after resetting the router using the button on back of the router. Wireless connections work, but when the hard wired ports try to connect and acquire an address from the DHCP server on the router they fail to connect. I tried assigning the the addresses manually, but I still can not get to the internet or any other computer on the network. Does anyone have any thought?
  • Blue_Rampage May 31, 2008
    I have fixed the problem by installing the latest firmware. The surprising thing is that the direction said it the upgrade needed to perform over a wired connection, which I did not have, so I did it wirelessly and it worked fine. One thing to remember is that once you do the firmware upgrade, the router will be sert back to the factory defaults.
  • 34 Answers
Please dont assign any manual addresses in ur computer..let it be automatic...
u said that u connected the computer to Ethernet ports in the router...
check whether the light are lit in the router corresponding to that particular port..
check the ip address to that particular computer(hard wired to the router)
ip address should be or 101 or 102..if the ip addres comes in this range means its working good...
if ther is no ip means please follow this steps...
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights turn on the router and wait
till the power light is the internet Explorer it should work..
Posted on Jun 03, 2008
Only secure sites work on wpn824
Have you made any changes to the router? Blocked or port forwarded port 80.
May 30, 2012 | NetGear RangeMax WPN824 Router
My wireless connection is running super slow AND I cant access the router via
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
1 Answer is not going to router settings on my web browser when typed into address bar like it usually does.. Any known issues or problem solving knowledge?
Try If that doesn't work then try connecting to the router hard wired using IE as your browser. Sometimes with some routers they can only be connected via an RJ 45 cable. Some routers like Linksys only like IE as the browser for accessing the router settings.
If you continue to have problems then reset your router. There is a tiny button recessed on the router back. Using a pen point hol the button in for 30 seconds and then try accessing the router.
Good luck.
May 15, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
connect the router wan port to one of the modems lan ports,
then connect to the router per lan or wlan and everything works.
Feb 24, 2011 | NetGear WNR2000 Wireless Router
Ip address not found please can you help me model no wap54g (eu/la/uk)
Are you trying to connect wirelessly or vie Ethernet? If wireless, make certain you have the correct security key entered. If wired, try another port. Worst case scenario, hard reset the router by holding in the recessed button on the back of the router for one minute. This will cause all settings to be reverted back to factory default, however would allow you to reconfigure your router.
Sep 28, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
Problems connecting my desktop
Press and hold the reset button on the router for 30 seconds. than turn the router OFF and turn it back On after 5seconds.
Than Restart the computer.
Please keep the post updated.
Jan 10, 2009 | Linksys WRT160N Wireless Router
Internet Intermittent Drop Out
To isolate the problem beter connect your wireless router directly to the modem and configure it, check if you are able to go online properly so that you can figure out the problem if your wireless router is not working properly, try upgrading the latest firmware and reset the router and reconfigure the router and that will fix your problem...
Oct 22, 2008 | Linksys Wireless-G WRT54G Router
No internet signal from router
To isolate the concern, it would be better to test the non working computer to the modem. If it works, that means there is a problem with the router and if it isn't then it is a problem with the pc..
If the computer works fine on the modem, you can try the following to check if the router works fine:
1. The modem should be connected to the router's WAN/Internet port.
2. The computers should be hard wired to the router's numbered port
3. On the router's setup page, go to the Status tab and check if the Internet IP address and the DNS are populated. If not, that means the router is not functioning correctly.
4. Go to the wireless tab and make sure that the SSID is customized. Make sure that the wireless computer is connecting to the said SSID.
If those had been checked and it still does not work, you can try updating the firmware of the router, reset and reconfigure it.
However, if the computer does not work on the modem. You may need to have it checked.
Sep 05, 2008 | Linksys WRT300N Wireless Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
107 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
