My WS-A65 mitsubishi TV does not turn on when I press the power button on the TV and remote. The outlit has power.
  • 1030 Answers
SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Posted on Jan 08, 2008
ctf1800
  • 4402 Answers
SOURCE: mitsubishi rear projection tv won't turn on
know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
SOURCE: viewsonic N3251 doesn't turn on right away
Solution... Call viewsonic and **** till you get a new one (diff model). Good luck, you're going to be on hold forever.
Posted on Feb 10, 2008
Maanita
  • 1142 Answers
SOURCE: Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
Posted on May 19, 2008
freetek
  • 5568 Answers
SOURCE: Vizio VX32L No Display and Can't Power Off
Old messages and bcipollina is gonna get to read this resonse twice; sorry-
If it just fails to turn on or ignores the remote, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
BTW, from what I have read about Vizio, I think they are close relatives to iLo which was also sold by Wal-Mart.
Quality control anyone?
Posted on Oct 25, 2008
Tip
Reset Mitsubishi WS-73711 VChip Password
Bypass or Reset Mitsubishi WS-73711 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 73711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-73711 Manual Download
Bypass Mitsubishi WS-73711 Front Lock
on May 05, 2010 | Mitsubishi WS-73711 73" Rear Projection...
Tip
Reset Mitsubishi WS-65712 VChip Password
Bypass or Reset Mitsubishi WS-65712 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65712 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65712 Manual Download
Bypass Mitsubishi WS-65712 Front Lock
on May 05, 2010 | Mitsubishi WS-65712 65" Rear Projection...
Tip
Reset Mitsubishi WS-65711 VChip Password
Bypass or Reset Mitsubishi WS-65711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65711 Manual Download
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Reset Mitsubishi WS-65511 VChip Password
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-65511 Front Lock
Mitsubishi WS-65511 Manual Download
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tip
Reset Mitsubishi WS-55711 VChip Password
Bypass or Reset Mitsubishi WS-55711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 55711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-55711 Front Lock
Mitsubishi WS-55711 Manual Download
on May 03, 2010 | Televison & Video
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS-55711 55" Rear Projection...
Tip
Reset Mitsubishi WS-48511 VChip Password
Bypass or Reset Mitsubishi WS-48511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-48511 Front Lock
Mitsubishi WS-48511 Manual Download
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
Electro Med Services...
