Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Shutdown problem am using windows xp pro with sp2 and my computer takes a very long time to shutdown and sometimes it wont even shut down unless you turn off the power. Please help. parola 3841
    Guru:
  • 1,342 Answers
Several things to check can be found HERE
Posted on May 31, 2008
Why does desktop pc running win xp pro, when choosing "start/shutdown/restart", fail to restart, but if choosing "start/shut down/shut down" it works fine?
http://superuser.com/questions/14163/when-windows-xp-wont-restart-how-to-diagnose-how-to-shutdown-without-power-c
May 23, 2014 | Computers & Internet
Windows does not displayed after boot, just "black screen".
Next time that you start windows, hold down the left shift key, that should prevent programs from starting automatically as windows boots. If the computer then operates normally, then take a look at your startup list (use msconfig). Otherwise...
Try starting in safe mode, see if problem still exists. If it does, something is going on with core windows system files. If not, then a program (which automatically starts) or driver is causing the issue.
In either case, you can also start in safe mode, but a version that prompts you if you want to load every file (and there are a bunch of them). The last file that is loaded before problem appears is usually the culprit.
Good Luck.
Jun 19, 2010 | Microsoft Windows XP Professional SP2
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
Won't shut down completely
If shutting down XP takes what seems to be an inordinate amount of time, here are a couple of steps you can take to speed up the shutdown process:
  • Don't have XP clear your paging file at shutdown. For security reasons, you can have XP clear your paging file (pagefile.sys) of its contents whenever you shut down. Your paging file is used to store temporary files and data, but when your system shuts down, information stays in the file. Some people prefer to have the paging file cleared at shutdown because sensitive information such as unencrypted passwords sometimes ends up in the file. However, clearing the paging file can slow shutdown times significantly, so if extreme security isn't a high priority, you might not want to clear it. To shut down XP without clearing your paging file, run the Registry Editor (click Start > Run, then type regedit in the Run box) and go to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
  • Change the value of ClearPageFileAtShutdown to 0. Close the Registry, and restart your computer. Whenever you turn off XP from now on, the paging file won't be cleared, and you should be able to shut down more quickly.
    Note: Please be careful when editing the Registry; you can do a lot of damage here. Don't change or delete anything unless you know exactly what it is.
Apr 13, 2009 | Computers & Internet
Computer restarts on shutdown
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
Windows XP stops at "shutting down"....
It seems to me that You need to uncheck the "delete paging file at shutdown". Deleting the paging file slows the shutdown of Your system considerably.
Jan 11, 2009 | Microsoft Windows XP Professional With...
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
Continuous loop and cannot charge battery
Windows service pack 2 is a huge update and takes a long time to complete, I will suggest walking away from your computer and having lunch, go to sleep, watch a movie, etc... while the update finishes. If you have already done this with the same result? I would look for a Windows XP SP2 disk (XP with service pack 2 integrated) and try that. Otherwise Microsoft sent out many disks containing the SP2 update itself on a disk, and you could try the SP2 update from one of those (if you can find one) after your clean install.
Good luck.
Feb 24, 2008 | Toshiba Satellite Pro M15-S405 Notebook
Hard drive heads crash upon shutdown
Dear delfixya
Hard Drives have one running speed once they are fired up, unlike a car engine which can idle down when not driving. They don't spin down until the power is shut off, and that is after all data is safe and RAM is not shadowing data from the HD.
Hard drives making clicking sounds after shutting down is an imminent sign of impending failure of the heads. Replacement is the best thing.
Feb 18, 2008 | Microsoft Windows XP Professional With...
have you checked that acpi is enabled in the bios and also look in control panel, then power options and check the shutdown options are correct and not set at restart.
Apr 19, 2007 | Dell Dimension 8400 PC Desktop
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
