Question about Cuisinart 12-Cup Programmable Coffeemaker - Black/Stainless-Steel
How does the Cusinart DC1100 cleaning cycle work? The light is on. What do you add to clean and what do I have to do?
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: The ''clean'' light is on my cusinart coffee maker
Let a half caraffe worth of distilled white vinegar sit in the water reservoir for about an hour. After the hour, turn the coffeemaker on and let it brew the vinegar until a small amount of vinegar appears in the caraffe. turn the coffeemaker off and let it sit for an additional 20 minutes. Then turn the coffeemaker back on and let it brew the rest of the vinegar. Then run a full caraffe of plain water to flush the vinegar out. If the self-clean light remians on - unplug the coffeemaker for 20 minutes or longer - if you unplug it for any less than 15 minutes, the coffeemaker will not reset itself. You should be good after that - as long as you do some sort of vinegar/water cleaning once a month henceforth.
-Tha Mp3 Doctor
Posted on Mar 14, 2009
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
The light has come on that says it is time to clean the washing machine but I have no idea how to do this
Just add some bleach to the wash cycle only then run like it has a load it should clear the clean cycle
Aug 21, 2011 | Maytag Bravos MTW6600T Top Load Washer
The cleaning light will not go off after i clean it
HI
If you are talking about the Clean button on the left.
After 250 cycles the machine needs to be cleaned. Push and hold the clean button for 5 seconds. Takes about 25 minutes. Add cleaning agent if you want to the brew unit.
You can turn the clean button off in the programing mode. Just push the the small cup button and the light should go out.
Feb 17, 2011 | Solis Palazzo Espresso Machine
I keep running the vinegar and water solution through my coffee maker but the red clean button keeps blinking. It has to be clean by now. What do I do?
This may or may bot work but I had to call Cusinart myself about the clean light. They said to unplug the unit for 1 hour then reset the time clock and the Auto Off setting. This supposedly resets the unit back to the "Factory Settings" If after trying this it does not work... most likely the sensor is bad.
I can so relate to the stupid light. I was about to give up on mine and get another one as it would was becoming quite fussy. I was able to save my unit by using a cleaning product called "Eliminate Shower Tub & Tile Cleaner" I did not do a clean cycle. I just added the cleaner in the water reservoir overnight and let it sit. Then dumped the contents out (lots of gunk) rinsed it well.and performed a normal 1/3 cup vinegar 2/3 cup water cleaning cycle and finally did a 2 pot water only rinse. The light finally went out after doing the unplug for 1 hour reset the clock and Auto Off setting routine.
The cleaner is very hard to find.
http://www.unelko.com/store/product.php?productid=16151
I bought mine at Home Depot and most HD assistants have never heard of it. It is also available at many janitorial supply companies. One final note... soak your shower heads in this stuff overnight and it is like a miracle! They look brand new! Too bad the fragrance odor it has is a bit much for the senses but what a product!
One more... link. This is what the original product bottle looked like.
http://www.supremehardware.com/servlet/the-35546/Eliminate-Tub-&-Tile/Detail
Lets hope you have the same success. I would try the un-plugging it for 1 hour thing first.
Just really trying to help you.
Thanks for choosing FixYa,
Kelly
Jan 20, 2011 | Cuisinart DCC-1200 Coffee Maker
The light is on to clean it and I do not have an owner's manual. Can you please explain? How do I get the light to stop blinking?
Most coffee makers are cleaned by filling the reservoir with undiluted white vinegar (3 cups). (Do not add coffee.) Remove the water filtration disk if you use it before starting. Then start the brew cycle as if making a cup of coffee (including putting a paper filter or the permanent filter in the filter basket and close the lid). Put a decanter on the warming plate. After brewing, turn off the coffee maker and let stand for 30 minutes. Run another cup of vinegar through the coffee maker. Take the decanter filled with vinegar and discard the liquid (pour down the sink drain). Rinse the decanter. Fill the reservoir with clean water and put in a new paper filter (or clean the permanent filter and put it back). Again do not add coffee. Run a brew cycle to rinse the unit. Discard the water that is in the decanter after the brew cycle. Do a second clean water only brew cycle (with new empty paper filter or permanent filter after cleaning again). However, if you notice an odd taste, repeat the rinse cycle.
You can alternatively use the Mr. Coffee Coffee Maker Cleaner (mix as directed on that package). In either case, this removes mineral deposits (calcium from hard water). For soft water, the cleaning should be done every 80 brew cycles. If you have hard water, do this every 40 cycles.
The manual is available from www.mrcoffee.com/Product.aspx?pid=121 , if I have the correct product version. For some reason this site isn't coming up for me today. Check the manual to find out if there is any specific details for cleaning that aren't shared with other Mr. Coffee products.
I hope this helps.
Oct 29, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
I have a PSTX Series of Mr. Coffee and the clean light is on. I have cleaned the coffee machine and light still won't go out. I even unplugged it for awhile and it still comes on after I make a pot of...
Had the same issue. You have to let it run a cleaning cycle before before the light goes off. Turn machine off, empty pot, add 4 cup cleaning solution and hit the clean button (not the brew button). Let it go through this slow cycle like it says in the manual and it should reset itself.
Oct 08, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
What does the clean washer reminder light mean and what do I do to clean the machine? This washer was new in September, 09 and the light has been on for several weeks.
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset the indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Nov 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Miele Dishwasher G856 SC cleaning assistance
Yes run a cycle with 2 cups of vinegar to flush it out
Mar 15, 2008 | Dishwashers
Cuisinart 12-Cup Programmable Coffeemaker - Black/Stainless-Steel Logo
76 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
