Question about GPS
Aga 1201 manual - GPS
Hi got a briggs engineon a hayter osprey mower need a engine manual .the only engine numbers i have are 70702-1201-01-73101511 many thanks
Hi and welcome to FixYa, I am Kelly.
You can download your owner's and parts manuals here:
http://www.briggsandstratton.com/engines/support/operators-manuals
I think there is something wrong with the first 5 digits of your model number, because the model does not come up no matter how I transpose / mix the numbers. I think your close on the model number.
How many Hp is this engine?
You enter the model number in this format: 70702-1201-01 ( Hayter Osprey 24 - 30 inch mowers typically have 7 or 8 Hp engines.
Recheck your model number and then use the link about to download your manuals.
Thanks for choosing FixYa,
Kelly
Jun 01, 2011 | Briggs & Stratton Garden
AGA ERROR IN TALLY 2265
either your aga motor is bad or your board set is bad. Turn unit on watch the printhead while opening the cover. The printhead should move back and display "cover open". When you close cover the printhead should move closer to paper. If not bad aga motor or bad board set.
Dec 15, 2010 | Tally Dot Matrix T2265C Printer
I purchased the AGA-1201 remote start alarm system and am having a big problem. The car starts remotely, but only runs for a couple 5-6 seconds before it stops, it then retries two more times with the same...
if the starter keeps going while the car is running for those few seconds, the issue is with the tach signal wire that runs from the remote start module to a coil signal wire under the hood. check it and make sure the connections are good and the wire isnt broken.
Feb 17, 2010 | Vehicle Parts & Accessories
Aga not lighting
you have an electric head on you BM valve if you turn off the power the valve will shut off if you want it to work with no power i.e. in a power cut you push the lever on the top of the electric head to the left and behind the stop so it doesnt return and the bm valve will be on manual
Dec 03, 2009 | AGA Kitchen Ranges
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Jul 21, 2009 | Tally Matrix T2280 Printer
I don't know how to tell the amp ratings of these fuses
Electronic - PC Board and Small Dimension Fuses - PC Board & Small Dimension Fuses 1/4” Dia. x 5/8” to 1” length ferrule fuses
AGA Specifications Decription: Fast-acting fuse. Dimensions: 1/4· x 5/8· (6.4 x 15.9mm). Construction: Glass tube. Ratings:Volts- 125Vac (or less)
Amps- 1/16-30A
IR- 10,000 (1/16-11/2A @ 125Vac)
- 200A (2-5A @ 125Vac)
- 1000A (6-30A @ 32Vac)
Agency Information: CE, Std. 248-14, UL File E19180, UL Listed, Guide JDYX 0-11/2A UL Recognized, Guide JDYX2 2-12A. Features and Benefits: · Fast-acting for maximum protection.
· Size rejects insertion of other fuse types. Typical Applications: · Electronic Circuits Catalog Number Amps AGA-1/16 1/16 AGA-1/10 1/10 AGA-1/8 1/8 AGA-1/4 1/4 AGA-3/8 3/8 AGA-1/2 1/2 AGA-6/10 6/10 AGA-3/4 3/4 AGA-1 1 AGA-1 1/2 1 1/2 AGA-2 2 AGA-2 1/2 2 1/2 AGA-3 3 AGA-5 5 AGA-6 6 AGA-7 7 AGA-7 1/2 7 1/2 AGA-10 10 AGA-15 15 AGA-20 20 AGA-25 25 AGA-30 30
Apr 11, 2009 | Electrical Supplies
Problem to install huewai ETS 1201 modem driver
Mar 26, 2009 | Computers & Internet
Error code 1201
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
Nov 30, 2007 | Lexmark X4270 All-In-One InkJet Printer
Need code for apex 1201
Try this site -> http://www22.verizon.com/ResidentialHelp/FiOSTV/Remote+Controls/SetUp/QuestionsOne/84901.htm
Oct 10, 2007 | Motorola Mobility DRC800 Universal Remote...
GPS Logo
138 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
