Question about Intertherm Heating & Cooling
My intertherm air conditioner is NOT cooling my home. The fan is running but the home is not cooling. Temperature in home keeps rising even when thermostat is at a much lower temperature, ie went to 83 when set at 76.
    Guru:
  • 1,524 Answers
Check to see if compressor is running.
Posted on Oct 11, 2010
Why doesy intertherm air conditioner run most of the time
First off it may be undersized or too small for the area being cooled. the thermostat maybe un level if it has a mercury bulb. The cooling contactor could be stuck, or you may have wires shorted together.
Jun 22, 2014 | Intertherm Heating Cooling System 15kw...
Tip
Keeping your whole home cool with central air.
Sometimes it is difficult to keep your home cool in the hot summer months. Also, some areas of your home may still be hot where other areas are too cool. Try this method to keep your home cool evenly throughout. Before you get started make sure your furnace filter is new. This will allow for maximum air flow.
If your living space is a single floor plan:
  1. Turn the air conditioning on
  2. Switch the furnace fan from auto to on.
  3. Measure the temperature in each room.
  4. Close the vents by about half in the cooler rooms
  5. This will force more cool air into the warmer rooms.
  6. Keep adjusting the vents until all the rooms have the same temp.
If your living space is on more than one level:
  1. Turn on the air conditioning.
  3. On the lowest level of the house close half of the vents that are the closest to the stairs.
  4. This will force more cool air to the top floor where it is usually hotter.
  5. Cool air will sink from the upper floors which will keep the area near the stairs cool.
  6. Measure the temperature in all the rooms.
  7. Keep adjusting the vents until you have a nice even temperature throughout the house.
I found that leaving the furnace fan on all the time will keep your home evenly cool and comfortable. You may have to replace your furnace filter once a month due to the increased air flow. It will be well worth it in a cooler, more comfortable, and more energy efficient home.
Take Care,
Eric
on Aug 09, 2010 | Heating & Cooling
Intertherms fan stalls
If this fan uses a run capacitor, I'd check it and its wiring and connection first. No problem there ? Then ohm out the motor winding in the fan. If this is a variable speed ECM motor Then you may want to check the module for a burned out thermistor (inrush current limiter) or even check the wiring harness on the motor for tightness. If the thermistor is defective, you can order one from Digi key for less than $2 + postage, adn then solder it in or pay about a grand for a new motor.
Feb 22, 2013 | Intertherm Heating Cooling System 15kw...
Intertherm heatpump outside fan will not come on, replace fan motor and capacitor, fan will not come on what could it be
some times heat pumps have a fan cycling switch to keep the head pressure normal in cool weather or check the defrost relay for the fan when a heat pump condenser gets frosted it will stop the fan and reverse into cooling mode for a few min. to melt the ice and this function is done by a relay or a printed circuit board if it goes bad you wont have voltage to the fan
Sep 30, 2010 | Intertherm P3RA-060K Air Conditioner
Burner lights and stays lit, but fan cycles on and off.
That sounds like a fan switch problem.
fan switch temperature setting to high
differential to close
bad fan switch or
return air temperature to cool
Sep 23, 2010 | Intertherm P3RA-048K Air Conditioner
When ambiant temperature rised why unit trip?
Make sure the fan that blows air across the condenser is running. If not this will cause the discharge pressure of the compressor to rise and will shut down the unit. It will get worse as the temperature goes up.
Apr 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Wont heat a 1,500 sqft one story home..air is cold by time gets to far end of home..gas pack 3 years old
One thing you can do is slow the blower down, this
will give you greater temperature rise and heat evenly.
The length of the home is what is needed.
Its possible that you need to have dampers installed in your ductwork or you need a booster fan installed
on the ductwork that feeds that side of the house.
My guess is that you need 80,000 btu heat output
to come close to heat the house. Since ductwork is
sized for cooling you would need 36,000 Btu Cooling
output. More information is needed
Feb 14, 2010 | Ruud UAMB Air Conditioner
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
Heating & Cooling Logo
119 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
