Question about Dell Inspiron 8600 Notebook
Dell Inspiron 8600
This just started. After no activity pc starts in standby but hangs up with "preparing to stand by". I have to hold power button down to turn off and then restart.
Thanks,
  • 191 Answers
Reinstall systems display drivers
and first of all do an msconfig,
To start MSCONFIG click START and go to RUN. Type MSCONFIG and you will see the program open.
click on startup tab and then click on disable all
then click on apply
it will prompt you to restart the system
once your system restarts do remember to put a check mark in the box which says do not show me this message again
Posted on Jun 04, 2008
Lost power during bios update
This is a state your BIOS corrupted. Re-installation may not be successful. Need to re-program the chip with original BIOS.This process is technical and need expertise in that. I really don't know a BIOS reset will work for you. There is some steps you can try
Remove laptop battery and power cord. Press and hold the power button for 2-3 minutes. Put back battery and plug in power cord and start.
Remove the CMOS battery and all power in sources(laptop battery& AC adapter) and short the two terminals in the CMOS battery holder with a screw driver or similar thing. Then put back everything and press power button. I am not sure that these steps will bring your system into a working state.
try these steps before going to a re-programming
Hope this helps
Dec 11, 2012 | Dell Inspiron 8600 (8600-4Q11S51) PC...
What causes a dell inspiron 8600 to shut down and start up on it's own.
1.Memory problem
2.Battery total dead and loose contact of adapter power
check the adapter batttery connections
and next clean and replace memory(Ram)
Sep 17, 2010 | Dell Inspiron 8600 Notebook
How to rebot dell laptop
Usually three ways.
Start-turnoff computer-reboot
Three finger salute aka hold down CTRL and ALT and then press the Delete key. That will either bring up task manager where you can select reboot or it will just reboot if you press it again (depends on os version)
Hold down the power button.
Depending on your model there may also be a reboot button that you can poke. It is usualy hidden on the bottom somewhere.
Jul 09, 2009 | Dell Inspiron 8600 / Latitude D800 /...
Where are the touch pad settings for the Inspiron 8600?
Click Start->(Settings) Control Panel->(Classic View) Mouse.
If there are not enough tabs to configure, then install first Alps touch pad driver for Dell Inspiron 8600.
Apr 01, 2009 | Dell Inspiron 8600 Notebook
8600 inspiron fell wont boot
Hi there
The shock from the drop may have displaced the memory modules and the video drivers could be failing, take them/it out and re-seat them/it, then try to boot the pc again. If this does not work the hard drive has took the brunt of the shock and you have to run the recovery cd or partition. I must warn you however, that you could loose data if you have to perform a recovery.
Good luck and let us know how you get on.
Jan 15, 2009 | Dell Inspiron 8600 Notebook
Dump of Physical Memory
Put the Dell CD in the drive bay. Turn on the computer and start pressing <F12> key. It should say "Preparing one-tome boot" When the screen shows a selection menu for the boot device, use the arrow keys to select the CD and press <Enter> key. That should run the Dell CD. Follow the onscreen prompts to run diagnostics checks
Dec 16, 2008 | Dell Inspiron 8600 Notebook
Standby mode is not working..
goto control panel and double click on "power options" under that aplet is the settings for standby and also hibernate.
Dec 07, 2008 | Computers & Internet
Stand by and hang problem
This is going to be a simple software glitch. Start by doing a system restore. You may have to go back two or three restore points before it corrects itself. The restore should fix it, but if it doesn't, then you will need to run a system repair with your recovery or operating system disc.
Aug 06, 2008 | Dell Inspiron E1505 Notebook
Locked up
Try removing the battery, then hold down the power button for 10secs and then put the battery back in, then connect the power cord back up and switch it on.
Once you get back to the desktop run a test on the HDD.
Cheers
Jun 17, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 8600 Not Powering Up
have you checked all connections to the battery, make sure the battery terminals are free of cerrosion(rust&mold) make sure alll the power cables are intact. it does not sound like the power supply due to the fact that the light is coming on for a min or so.
May 11, 2008 | Dell Inspiron 8600 Notebook
Dell Inspiron 8600 Notebook Logo
106 people viewed this question
Alun Cox
