Question about Dewalt Saws
Need a on off swich and measurement for a cutting deck .to replace an old one.
  • 30 Answers
Parts for DeWalt tools can be ordered through your local Factory Service Center,at 1-800-4-DeWalt or though www.dewaltservicemet.com You can use the website or 800 # to find your local service center.
Posted on Oct 11, 2010
  • buysellgb Jan 23, 2011
    DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
    We have 15 years developing experiences and will implement the advanced products to our customer.
    Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
    * Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
    * Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
    * Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
    70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
Uneven Cutting with my Zero Turn 50"...Possible Causes?
First is being sure all your tires have proper air pressure and you don't have a bent blade. Then while parked on flat concrete and both outside blades at 3 and 9 o'clock measure blade height far left side of deck and far right side and compare. I there is a difference the entire deck is out of level and should be adjusted. Then remove the blade drive belt from one of the pulleys so everything is slacked. Grab each blade and see if it wobbles or has excessive play and check the spindle housings for cracks or breaks. If you find a housing with wobble or play the bearings in that spindle are shot ( this is a lot harder to detect with the belt tension on the pulleys) and should be replaced. If you find a broke or cracked housing the housing will need to be replaced. Either one of these situations may not be obvious with the mower at rest but the blade will wobble at speed causing uneven cuts.
Aug 25, 2014 | Garden
Husky yth1542xp. I've changed the blades, leveled
When levelling the deck, rotate the blades so that the right blade has one of its cutting edges at or near the right side center of the deck. Do the opposite with the left. Measure to the blades from the level ground, not to the deck. Try leveling that way.
Gary
Jul 03, 2011 | Husqvarna Garden
Replaced blades duel deck high spot in cut grass on right hand side. thanks.Mower is rover lawn king.
Try leveling your deck beacuse it sounds like the right hand side of the deck is too high causing the high spots. move the mower to a flat surface, drop the deck to its lowest point and measure the deck height with a tape measure.
Nov 27, 2010 | Garden
I had hit a somewhat hidden stump on the lawn..bending the blade. Took the deck off and replaced the bent blade. Put the deck back on and now the cut seems uneven. It appears that the deck is now...
I've only had luck removeing the deck, turn it upside down. Measure blade, mark, remove blade, insert large pipe over spindle, bend in direction. Re-install blade, and do it all over and over till straight. Measure in several locations.
Aug 18, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
My mowers cuts uneven I replaced the blades but it still cuts uneven how can I level it?
Park mower on a level flat surface ( a concrete garage floor is ideal ) lift deck up until you can put a piece of a 2x4 flat underneath the deck and lower deck until it just contacts the 2x4. loosen adjustment nuts or turnbuckles and adjust until the deck just starts to clear the 2x4. this should level your deck. Now , lift the deck and remove the 2x4. put blade height lever on a known cut length and with a tape measure, measure the tips of the blades from the floor to the blade tip...they should all be the same within 1/8 of an inch...if not then you either have a bent blade, bent spindle shaft, or spindle bolts are loose or misaligned. Your deck could be warped too...depending on how hard a lick it took...good luck !!! ;-D
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Oct 01, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Yardman riding mower cutting uneven
You need to park on a level area and lower the deck to it's lowest setting and adjust the deck with the large butterfly nuts on each side,just under the foot pan,just loosen and let the adjusters fall into place,Tighten back up and it should be set.
May 15, 2009 | LG enV VX9900 Cellular Phone
Craftsman LT1000, model 917.272059 - cutting deck misaligned
Go to www.managemyhome.com and download the manual. Make sure you type in the model # without the period (i.e. 917272059).
Apr 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Saws Logo
44 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
