Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Water is not draining out when thru with cycle?
  • Whirlpool Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 11, 2010
Water does not drain at end of cycle
Could be drain pump , float switch, or PCB. Does it initially go thru a drain cycle when you start a cycle? Is there water in the bottom of the tub?
Oct 02, 2013 | Bosch 24" Built-In Dishwasher - SHE43R55UC...
2 problems one water escaping to the drain freeze cycle short
first, freeze cycle too short because you are loosing water. Water may be leaking thru the dump valve. Look at drain while machine is running and see of alot of water is draining. The dump valve spring may be week or there is trash in the dump valve preventing it from seating properly. drain water first before pulling dump valve apart.
Aug 29, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
When it gets to the rinse cycle, water is coming out of the hose into the sink not allowing it to fill, but their is a continuous dribble of water coming out of the hose into the washer, so whatever goes...
maybe your diverter valve at the pump is stuck open. Its a lilttle red box looking thing under the waasher by the pump. That little red box looking thing is you wax motor that has a plunger hooked up to a small looking piece. That wax motor moves the pluger in and out depending what cycle it is on. So im thinkng that went bad maybe and has the valve stuck open and thge water that is trying to fill is passing thru the pump and thru the drain hose. When the water fills its supposed to be closed tha way it contains all the water when it fills and wont let any get thru pass the pump and thru the drain hose.
Aug 05, 2009 | Fisher and Paykel GWL11 Top Load Washer
FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Feb 13, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Dishwasher will not go thru wash cycles
doy you hear any sound from either in the wash cycle
Feb 11, 2008 | Dishwashers
Washer won't drain
model number is LHW0050P,
thank you again,
Susan
Jan 13, 2008 | Washing Machines
Washing Machines Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
