Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Is the PT50LC13 a digital TV? I didn't buy a converter box thinking that the TV didn't need one, but over time and unable to see any channel even with one, I wonder if the TV is indeed digital or not. I can see perfectly movies played with my DVD player, or with cable TV, but what about receiving signal of local channels without paying for the service? I don't know what else to look for, can you help me please?
  • Panasonic Master
  • 5,103 Answers
This tv only has an analog tuner (NTSC). That is why it works with cable and dvds. You will need a converter box to view OTA signals. (In addition, digital signals have a firm cut-off of signal strength; if the tuner doesn't get enough signal the channel will not be available.) So check with antennaweb.org or tvfool.com for details on the antenna direction for your area channels. antennaweb is very conservative in the channel listing it provides (even with the assumption of an external antenna). tvfool gives the color specifications of the antenna that should receive a given set of channels in your area.
The converter boxes are still available from select vendors but the government coupons program is not. Here's one that is listed as in stock: http://www.radioshack.com/product/index.jsp?productId=3150939&CAWELAID=198809366 . This is one of the standard definition output boxes. High Definition digital to analog converters also exist but are more expensive.
A cheap alternative may be to use a PC TV tuner (either USB or internal card) attached to the antenna and then output to the TV. This TV has a VGA port. (If you want to use component video in on the TV, you will need to check if your video card will support the non-RGB signal or a converter box for that.)
I wish that I could be of more help.
(many shows are available online either from the networks or from hulu.com)
Posted on Oct 11, 2010
How do ihook up to a second tv from ikonvert digital box
your going to either buy a share, Y-cable to run both tvs, or switch box to select the tv you want to watch a that time
the connector on the tv has to match the connectors on the converter box.
just remember you will be watch same channel at the same time
you could also leave everything hooked up, than get Y-connector and put on the output of the box run line to each tv your still be watching the same channel without doing a lot of work and time
Mar 10, 2015 | Supersonic IKONVERT Digital TV Converter...
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
How do I get the free digital channels on my tv?
One way you can get free high quality digital channels is an HD antenna. In recent years, the government stopped broadcasting analog (non-HD) signals, and instead pumped out HD. They advertised their "converter box", that made it possible for people receiving their TV channels from antenna, to get HD.
If you currently have an antenna that you prefer to use, you can buy a converter box here.
But, the solution that in the end will get you more channels is a new HD antenna. They range from extremely powerful roof antenna's, to average tabletop antenna's. A roof antenna has more distance, but can be more hard to set up compared to the tabletop ones.
You can buy a variety of tabletop ones Here
Or, you can choose outdoor Here
You can learn to set it up Here
If your TV doesn't have HD capabilities ("HDTV") than you will need a converter box, which can buy at the link above ( or here.).
Hope this helped!
Be Sure To Rate macapplezoo 100% Or Whatever You Think I Deserve!
Jun 05, 2011 | Televison & Video
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
How do I use my VCR with the DTV Converter Box that I had to get?
You only have three choices that I know of. The first two are a bit expensive though. 1) Buy a digital TV, then you could split your antenna cable to the TV and Converter box. Then use the converter box as the tuner for the VCR. 2) Buy a digital VCRand do the same thing using the converter box as the TV's tuner. or 3) Get a second Converter box and split the incoming cable between the two, using one for the TV and the other for the VCR. If you use any of these ideas, remember that You need to not have the VCR and the "new" tuner for the TV set to play on the same TV channel, and that you switch teh VCR out of VCR mode with the TV/VCR button, so that you get a clear signal on the other channel. If anyone has an easier solution, I too would like to know about it, seeing as I am in the same position and would like to avoid this problem as well.
Jan 02, 2009 | JVC HR-J692U S-VHS VCR
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
Need to know if my tv is digital or analog?
most new tv's are digital capable...
but here is the trick the convertor box are only for those who don't have cable or satellite service if you use only an antenna to get channels then yes you will need a converter box for each tv that uses only the antenna to get channels if you have satellite or cable service then they don't need a converter box even if they have basic cable they won't need the box there channels are already digital converting now there are a few events that was in anlog but there are being converted as best as possible but you may notice the difference in the pictures betwwen analog (usaully old time movies or show even commercials) Digital (most everything now that are new stuff are digital and even in hd now)...
Nov 12, 2008 | Televison & Video
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
431 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
