Question about Fisher and Paykel IWL12 Top Load Washer
Fisher and paykal IWL16 washing machine showing fault 37 tub not emptying or spinning when put on spin cycyle
  • mbalch Oct 12, 2010
    had to replace the entire pump, but thanks for your help
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Error code 37 means PUMP BLOCK ERROR.Drain some of the water by hand enough to look under the machine to the front right.Do you see a fan.If you do this is your pump.If you do not see a fan then you have the new style of pump.Please reply on which style of pump you have and I will guide you in rectifying this fault.Looking forward to your reply.
Posted on Oct 11, 2010
  • mbalch Oct 11, 2010
    there is a fan
  • luisa_sgro Oct 12, 2010
    Hi just read your posting.Now turn the fan clockwise and then anticlockwise a few times to loosen the pump.The fan should turn freely.Now put the machine back on its feet and select a spin cycle and push the start button.The machine should start to drain.Please reply on how you got on and for further advice.Looking forward to your reply.
Fault code 37
If you wish to get some details about washing machine service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 27, 2016 | Fisher Washing Machines
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
My washer has fault 37 and we can smell rubber burning. The drum feels very lose.
On F&P machines the inner tub floats away from the dog clutch allowing the agitator to wash without attachment to the drum. When you empty the machine the inner drum settles back on the dog clutch and can be engaged for spinning. A loose drum when full of water is probably not a fault..
37 error is pump fault. Water level not changing.
The pump may be blocked/jammed and be overheating, or it may have failed.
You'll need to unplug the power supply at the socket.
You'll need to empty the machine.
When the water level is low you can lean the machine back to access the pump motor under the tub. Turning the fan blades can sometimes dislodge the obstruction. If the fan turns freely retry the spin mode to empty the machine..
If the pump is jammed you'll have to remove it and clear the port.
Make sure you've emptied the machine as any water left in it will run out when you remove the pump.
carefully study the pump before removal. Take note of the latch which locks the pump in position. Earth wire to open spade connector. Power wires to pump via plug. Remove and clean. Replace and test.
If the pump still overheats it should be replaced or it will damage other components. The pump resistance should be more that 33ohms..
F&P reccommend pump replacement if less than 33ohms.
Good luck.....Nomess
Aug 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Sep 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Hae we have a fisher and paykal washing machine but it wll not start spinning can u help
Run a diagnostic test for the spin cycle. The paper to show you how to run these test is located under the control panel normally two screws on the back of the control panel. By running the diagnostics, it will code if there is a problem and you will know what to check. You can also drain your machine with these diagnostics.
Does your machine beep (because there is a problem) during the drain process but doesn't get to the spin cycle? More than likely your drain hose is clogged. It is very easy to check this. I had the same problem because my machine could not drain properly and would not get to the spin cycle. There was a penny in my drain hose. There is a video on youtube that shows you how to do this (very informative).
Jan 19, 2009 | Fisher Paykel EcoSmart GWL15
Fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Sep 02, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
604 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
