Question about Sony Audio Players & Recorders
Sony cmt spz 90 db tuner will not tune either in FM or DAB mode
2 Suggested Answers
SOURCE: new sony hifi system with dab radio model cmt-spz90db
Posted on Feb 10, 2008
How Ido tune it l have no manual.Can you please help.many thanks
Radio With Manual Tuning - Alibaba
www.alibaba.com > Automobiles & Motorcycles > radio > radio with
Radio With Manual Tuning, Buy Various High Quality Radio With Manual TuningProducts from Global Radio With Manual Tuning Suppliers and Radio With ...
Help Guide ' Tuning in an FM radio station manually ... - Sony
https://www.sony.co.uk/.../emanual/.../TP0000016777....
Sony CorporationThe headphone cord of headphones is an FM antenna, therefore, connect headphones to the (headphone) jack when listening to the FM radio.
Tuner (radio) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Tuner_(radio)
WikipediaA tuner is a subsystem that receives radio frequency (RF) transmissions like radio ...Older models would realize manual tuning by means of mechanically ...
[PDF]Tuning into a Radio Station - Onkyo
Dec 16, 2015 | Audio Players & Recorders
How to use it on Win 8. It worked on Win 7 but now loads but will not tune in TV and does not recognise DAB or FM.
Make sure it is installed correctly, it may need to run in Windows 7 compatibility mode under Windows 8(.1) for the TV tuner to work.
Jan 03, 2015 | Computers & Internet
FM Tuner not receiving - Yamaha R7 receiver
Take the cover off and look at the cable that connects the tuner to the main board. Make sure it is connected straight and tight. Make sure all screws in the back are tight, just in case it is a grounding issue. Iff all checks out and you still have issues, replace your tuner.
Apr 30, 2012 | Yamaha Audio Players & Recorders
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
How to play an ipod using the (Audio in) system
On the remote click 'Function' and itll scroll through the settings.
Tape, CD, Tuner, Audio In.
Choose Audio In.
I know this may seem annoying but itll work.
Apr 12, 2009 | Sony CMT-NEZ3 Shelf System
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
FREQUENCIES
Typically, but not always, you can hold down a specific key on the front faceplate and hold it down while turning on the power. This will usually ONLY restore the AM channels from 9Khz spacing to USA 10KHz channel spacing, but I don't think it will restore the FM band; I could be wrong - do a google search.. Usually the FM band is Japan is different than ours, and there are some expensive adapters to upconvert/downconvert US FM stations, but not worth the money to add, in my opinion you should just buy a new tuner like the Sony HD radio tuner!
Apr 06, 2009 | Audio Players & Recorders
Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
May 15, 2008 | Audio Players & Recorders
DAB RADIO MATSUI MATCR 515D- ILLUMINATED TIME/STATION DISAPPEARED - NO RECEPTION - MUSH CAN BE HEARD IN SPEAKER
It is possible for the display to be set so low that it is not illuminated at all. With the radio off (i.e. the set must be in standby), press and hold TUNE+ to raise the brightness level.
If this gets the display back, you may be able to see what has happened to the tuning. e.g. check whether the tuner is set to FM or DAB etc.
Apr 29, 2008 | Audio Players & Recorders
64 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
