Question about Roper FGP325K Gas Kitchen Range
I have the roper gas kitchen range, and the shut-off valve is on the other side of the wall. Well I have a cat that jumps on the stove sometimes and knocks the black knobs sideways, turning the stovetop gas on, and sometimes fills my apartment with gas (dangerous). The valve is to the left and the gas is not off. Other sources I've read though say that if it's on the left, it's off! Which way is off??
    Top Expert:
  • Roper Master
  • 52,126 Answers
Get rid of cat END OF PrOBLEM
Posted on Jul 28, 2017
3 Suggested Answers
  • 3 Answers
SOURCE: my roper stove keeps clicking even when all knobs are off!!!
spilling water around spark control switches closed to burner control valves could cause that...may stop clicking in a day or so..or if on low flame setting the orfices on the burner head are carbon restricted? clean orfices with torchtip cleaners..
Posted on Jun 25, 2009
rickead1
  • 1998 Answers
SOURCE: i have a Roper kitchen
The constant indicator light indicates that it is shorted somewhere; perhaps welded contacts in one of the switches. Possibly a bad infinite switch for that burner, or an uninsulated wire making ground contact. Some electrical troubleshooting using a multimeter will have to be performed to find where the short is. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks Rick
Posted on Aug 11, 2011
Stove burners don't ignite ,the regulator isn't letting the gas go to the range kenmore gas stove model 665 75022101
First, check to make sure gas is actually getting to the range and hasn't been stopped by a clog or simply shut off accidentally. Next, make sure the120v AC is present. If you verify that gas *is* reaching the range and there is 120 volts getting to the range, then the main gas valve is next in line(where the gas line connects). The part numbers for the main valves in the range are:
8523378, gas shut-off
8054079, gas valve
I hope this helps you!
Sep 15, 2015 | Kenmore Kitchen Ranges
How do I install a whirlpool top gas stove?
You need a gas connection .then flex tube channel locks or a pipe wrench and some Teflon tape. Connection should have shut off valve.should be shut off. Put Teflon tape on threads then connect the connectors. Open valve.check your work twice listen and use your nose for a foul smell.
Jul 15, 2014 | Stoves 600SiDOm Gas Kitchen Range
Roper gas range. Oven glow coil comes on but has no gas to heat?
if the glow igniter is on and it doesnt light its probably the gas valve
Feb 12, 2012 | Roper FGP300 Gas Kitchen Range
I OWN A WOLF CHR 6-29 GAS STOVE AND WANT TO SHUT THE GAS OFF TO THE OVEN PILOT LIGHT. i AM NOT SURE WHERE THE PILOT VALVE SHUT OFF IS OR WHAT IT LOOKS LIKE.
You should be able to blow out the pilot, after 30 seconds or so the fuel flow should be stopped by the oven safety (usually has the red button on it) If that does not work, the pilot is either fed from the gas manifold on the top (sometimes has a small needle valve to shut off, or it could be fed throught the safety valve. The valve will have an adjustment in it, usually under a cover screw. If the pilot fuel flow does not stop when there is not flame present, You should have the safety valve replaced. This can be a potentially hazardous scenario. Hope this information helps.
May 04, 2011 | Wolf Range CHR-6-29-FT22 Gas Kitchen Range
What space is required behind range to allow for gas hook up
If you follow the installation directions for this range, you should be able to have zero clearance from the wall IF the electric outlet and gas shut off valves are located in the proper places. The gas valve should not protrude more than 2" from the back wall in order to have the stove sit flush against the back wall, when pushed all the way in.
Here's a copy of the installation instructions from Jenn-Air for your stove. Please see page 10 for their recommended location of the electric outlet and gas supply line and shut off valve
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P629-60.pdf
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My roper stove keeps clicking even when all knobs are off!!!
Jun 24, 2009 | Roper FGP210 Gas Kitchen Range
Gas Odor and Oven Heating
The gas valve may be failing. The 'whooshing sound' you hear may be the gas valve closing too slowly when the oven cycles off or the cavity is filling with gas and igniting when the oven cycles on. The gas you smell may be an indication that the valve is not closing completely. This can be potentially dangerous if the oven fills with gas then ignites. I would not operate the stove any longer and shut off the gas to the stove.
Jun 26, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Burner goes out on simmer
look down the shaft of the burner valve(remove the knob). with a very thin and somewhat long screwdriver you should be able to adjust this flame, with the burner on MED hold the shaft of the valve with a pair of pliers and turn the screw slowly( you'll need to hold the shaft tightly because if not you'll be turning shaft and not adjustment screw. small increments yield big changes in flame
Mar 07, 2008 | Roper FGP325K Gas Kitchen Range
Ge spectra gas stove top not lighting
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Nov 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Roper FGP325K Gas Kitchen Range Logo
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Craig Butler
Craig Butler
Jim Thurston
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
