Question about AOpen AX4B-533 Motherboard
No start up, no bios boot , only "no signal "on screen
Motherboard do not start up anymore . already removed all extension cards . 1 red "led" is on ( 2 cm up the CMOS Clear jumper ) an other red e "led" is flashing ( near the right under corner off the Intel 845E chipset .
Any sugestions ?
KR
Marc
  • grandscenic Jun 01, 2008
    cpu fan is spinning .
    KR
    Marc
    Scholar:
  • 187 Answers
Is the CPU fan spinning? if not, check the coolant between the CPU and the cooler (ensure it's not dried up, and replace it if it has or if there is very little there).
Posted on May 31, 2008
  • Steven Burn
    Steven Burn Jun 01, 2008
    If the CPU fan is spinning but the system is not booting, check your IDE cables, drive power cables etc.
SHUTDOWN ALL OF A SUDDEN WHEN I'M CHEKING MY EMAIL, I TURN IT ON, STAYS ON, CAN'T BOOT, INSERTED OS TO FIX IT BUT JUST SPIN AND STOP, POWER STAYS ON AND FANS ARE NOT MOVING, BLINKING LIGHT IN MOTHERBOARD,...
what hardware have you replaced? do you hear a beeping sound? try removing everything (HDD, DVD/CD/FLOPPY/)except the proc,video card and mem on the motherboard and try to boot. check if it will give you bios. if it still the same, do an isolation test. the main reason why its not responding is your computer doesnt complete POST. POST is one of the process the computer do to test all the hardware that is connected on the motherboard, if one fails and POST doesnt complete, you wont see the BIOS startup screen. Theres a lot of possible fault on this concern. since theres a lot of things connected on the motherboard
Mar 27, 2011 | Gateway Profile® 6C (PROFILE6C) PC Desktop
Hi, PC lost network connection then subsequently no boot, no video signal..... 4 LEDs at the parallel ports side of the motherboard has only RED - GREEN - RED - RED starting from motherboard and...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 25, 2011 | MSI 845 PRO Motherboard
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
NF7-S2 No POST on startup. Can Not get into Bios
In that case the motherboard itself is faulty replace it..
Jun 08, 2009 | Abit nForce2 NF7-S2 Motherboard
Iwill bd 133/no boot screen/no activity in hdd led
press the delete key repeatadly while booting up and you will go into the bios. then find boot sequence and set your harddrive to 2nd boot deviceand your cdrom to 1st. also if it says no signal check your graphics card connection if you have a seperate graphics card. if you do have a seperate graphics card remove the screen cable and connect it to the onboard graphics instead. if this still does not work then remove the small battery on the motherboard for around 30 seconds and replace. then repeat the above steps. removing the battery will reset your motherboard.
thanks
please rate me and give me a fiya! if it works for you.
Apr 05, 2009 | Iwill BD133U Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Jul 22, 2008 | Intel Motherboard
Booting problems
As you probably have already figured out your motherboard is running into some type of error during the boot process. Try restarting the computer and pressing the del key several times after a second or two. Can you get into the BIOS now? The first thing I would do is to make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. Unplug your computer, plug it back in and reboot, paying close attention to anything that is displayed on the monitor and noting any changes from before. If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Jan 06, 2007 | MSI KM4AM-V Motherboard
AOpen AX4B-533 Motherboard Logo
254 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
