Question about Compaq 113897-002 - PCI Sound card
Problem installing audio driver on via onboard km 266 pro-835 - realtek - say"Unfinished installing/problem installation with exclamation point.
5 Suggested Answers
yehanny
  • 34 Answers
SOURCE: need Realtek Ac'97 Audio for VIA (R) Audio Controller driver
here you can download it for free in all windows versions... http://www.radarsync.com/drivers/d131057-realtek_ac%27%2797_audio_for_via_%28r%29_audio_controller
don't forget to rate!... xD
Posted on Jul 05, 2009
  • 742 Answers
SOURCE: I already installed a realtek sound driver several
please make sure that you have enabled or adjusted the proper volume levels using the Master Volume control found at the system tray.
Regards!
Posted on Jul 07, 2009
yashrajsen
  • 61 Answers
SOURCE: new audio driver
Is this the original driver CD software? If you r downloading from the internet,then check for the exact specifications and download.
If u download and install other versions or diver name realtek ,then there may be some mismatch with the motherboard.
Posted on Jul 09, 2009
sspsychotic
  • 77 Answers
SOURCE: i have compaq presario c300 but sound driver is not installing
check if the sound card is installed firmly, clean the copper plates at the bottom with an eraser just like your erasing dirt from paper and the last solution clean your mobo and sound card.
Posted on Sep 07, 2009
Realtek audio driver 5.10.0.5423 installation problem on my pc
Hi There,
Go to the Intel website, ...
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2766&lang=eng
Select your operating system, and download the audio driver for your device.
Before you install it, restart your pc ,Log into the Bios, make sure that your onboards audio is enabled might say onboard AC97.....
Then go and install you driver for the device, Hope that helped you, IOf not let me know
Regards
techmor
May 28, 2009 | Intel D945GCCR Motherboard
Realtek ac'97 audio driver problem
try to look first the brand of your sound card what model and type. i think you can already download the installer in the internet.
and i also think that you need your motherboard's installer to fix it if you still have it. because it has all the features for your computer.
May 01, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Avance ac'97 audio for via audio controler
You should be able to use the AC97 codecs available from Realtek for your device. There is a choice of two - standard AC97 or AC97 HD (both are available from the link provided), one of these should be compatible.
Post your results here, especially if you encounter a problem installing the drivers or if this doesn't fix your problem.
Apr 10, 2009 | Computers & Internet
Driver sound on mainboard
Realtek AC'97 Audio for SiS(R) Audio Controller 5.10.00.3560
VIA advises that where possible, users should install onboard sound drivers provided by their motherboard manufacturer.
http://driverzone.com/device.php?id=50993
Greeting Peter
Mar 07, 2009 | Taiwan Semiconductor Co. TTP-246M Thermal...
"My widows xp-2 have no any sound"
hello sir,
1 thng u can do is try to re install the driver after uninstalling it n after installatio restart it.
do check the following points
-you r putting lead in green port.
-ur port is fully working
do reply
abhinav
Jan 10, 2009 | Acer Aspire 4720 Notebook
No Sound
ATI is the graphics card developer. Your motherboard has onboard audio that appears to be Realtek. You should not have an ATI sound driver... as they don't exist.
I'm assuming you're using WinXP to make thing simple. If you're using Vista, try to do the equivalent.
Since your graphics card is capable of HDMI, the problem could be that the card expects to output audio through your graphics card rather than the sound card. Check start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings -- go to the Audio tab and make sure it says Realtek for output. If it shows more than one output device, set it to realtek. If it doesn't show realtek, follow the below instructions, and then double check at the end that the Output device is set to Realtek.
1>Please go to HP's site and download their Audio drivers.
2>Go to Device manager -> Sound, Video, and game controllers.
2.1> Does it have an entry saying "Realtek blah blah Audio" there? If not, what entries does it have for audio? Ignore Audio Codecs and Legacy Audio Drivers.
2.2>If there's nothing there, you need to install the drivers you downloaded. If there is something there, please continue to #3.
2.3>After installing the driver, restart computer.
2.4>Once computer is restarted, go start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings. Hit the button labeled Advanced and adjust the speaker setup to whatever you have - surround sound, 5.1, quad, stereo, whatever.
2.5> Go to #5
3> If there is anything that says Realtek/Azalia Audi, right click it and Uninstall.
3.1> Restart computer.
4>Install audio driver you downloaded, and perform #2.4.
5>Find the driver icon (there's probably on in the task tray) or find it under start -> Control Panel -> Sounds and audio. Set your speaker settings there as well. Audio I/O should specify what ports go to what speakers What you set in windows should match the Realtek audio manager's speaker setup.
If problem persists, please report this.
Dec 14, 2008 | Computers & Internet
RealTek AC Audio97
hi sweets6;
did you uninstall the old drivers before you install the new one? try to un-install it first by right clicking the audio device then select un-install, restart, then install the driver, restart and try to see if it works.
let me know :)
Jun 18, 2008 | E-Machines etower 500ix PC Desktop
MV43V motherboard by shuttle
Here are your MB specs:
MV43V/N - Supports Socket 478 Intel Pentium 4, Celeron with 400/.533 MHz FSB
- VIA P4M266A + VT8235 Chipsets
- DDR 200/266 SDRAM, 2 x 184 – pin DIMM, Up to 2 GB
- 2 x ATA 133
- 4 X AGP device, 2 PCI slots, 1 CNR slot
- Onboard AC97 audio two channels
- Onboard S3 Pro-Savage 3D Graphics
- Onboard VIA VT6103 10/100 Fast Ethernet (MV43VN only)
- 6x USB 2.0
- Micro ATX Form Factor
The your motherboard has an ethernet adapter all you need to do is download the drivers for the ethernet adapter and install them. here is the link : http://members.driverguide.com/driver/detail.php?driverid=206328 do a free subscription first. cheers
T
YE
Feb 16, 2008 | Shuttle MV43N Motherboard
Motherboard driver
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=268
Oct 20, 2007 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Compaq 113897-002 - PCI Sound card Logo
37 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
