Question about HP OmniBook XE3 Notebook
When I turn on the computer I get two options 1-press ESC for boot menue. 2 press F1 to enter setup and then the screen goes blank if I dont choose one of the options. Omnibook XE3.
    Sergeant:
    Champion:
  • 387 Answers
Its either the Operation System or the Hard Drive try to start the computer with the instalation CD
Posted on Oct 11, 2010
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-s5057 12" 1.66 Ghz...
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
I have an HP Mini 110-3135DX. When I turn on the power all that is displayed is a blue screen and it wont boot. How do i fix it?
check you bios pages are correctly configured,,goto bios navigate with "tab" and arrow keys,,play around untill you know these pages dont change anything untill you are sure you know what you are doing..Exit and save pay attention to boot sequence if this is set up wrong it might cause failure in the way you describe,the instructions on the right hand side of the bios pages should help you---good luck --Davey
Jun 20, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
I made in bios a setup to boot fast and when i open the laptop the bios option it doesnt appear anymore , it is starting windows. how can i repare it .how can i acces the bios again?toshiba L655-S5058
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
May 04, 2011 | Toshiba Satellite L655S5058 Notebook PC
DELL latitude 100l, someone disabled all boot devices then set config / administrator password. Please help
Boot Priority on Dell Latitude 100L
  1. Turn On Your PC
    Have you ever noticed the messages that pop up on the screen as soon as you turn on your PC? These messages tell you a key combination you can press to enter "Setup" or the "BIOS." Watch your screen and see if you can read what keys to press.
  2. Press the Keys to Enter Setup Mode
    If you did not see a message telling you what keys to press, try tapping the following possibilities as you turn on the machine:
    • Esc
    • F2
    • F12
    • F10
    • F1
    After pressing Esc or other key, you will most likely see instructions telling you how to enter "Setup Mode". Follow those instructions.
    tip.gif On some computers, you must hold down the key before you press the power button to turn on the computer. For example, if you are converting a Toshiba laptop to a Linux Workstation, you must hold down the Esc key and then press the power button. The computer then asks you to press F1, and you can then set the "Boot Priority."
  3. Using the Arrow Keys, Choose the "Boot," "Boot Order," or "Boot Priority" Option
    The menu of choices you see will be different for different kinds of computers. Remember that the choice you want is the "Boot" order or "Boot Priority." On some computers, this is called the "Start Up Options" or "Start Up Sequences." You are going to change where the PC will look for boot information when it starts up. (CD-ROM, HARD DRIVE/HDD, LAN, FLOPPY, USB). If you wish to boot from your Hard drive, then select it as your First Priority.
  4. Using the instructions on the screen, save your settings and start up your PC. The PC must boot from the HDD. Regrds
Jul 01, 2010 | Dell Latitude 100L Notebook
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Unable to get to CMOS using any of the 3 methods
This machine is one of the first "legacy free" models which means there are no BIOS options to change. All settings and resources must be assigned by the OS.
For details, please check the "legacy free" FAQ on MS Knowledge base.
If you are trying to access the BIOS to change boot order so that you can boot from a CD, hold down the 'c' key during POST/boot. This will case your laptop to boot from CD-ROM.
Apr 09, 2008 | Toshiba Satellite 5005-S504 Notebook
Blue screen when starting up
just double check the keyboard connection if it's ps2 type connector; if it's a usb mouse it won't work cos the drivers have not loaded. Only other solution is to remove right side panel of pc and locate the JBAT1 terminal and move jumper from pins 1-2 to pins 2-3 for a few seconds and back again. Turn on pc and then hopefully you can access the bios to set the time and date and save settings then re start.
Jan 20, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
HP OmniBook XE3 Notebook Logo
99 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
