Question about Aerogrow AeroGarden
I don't believe the water is flowing through my Aerogrow Garden, it used to make a "trickling" noise and that has now stopped. My cascading petunias look like they are losing colour and they are only 2 weeks old.
  • admin360 Oct 11, 2010
    I am not sure if the Aerograden has a pump I will check the water channel to see if it is blocked. Do you not know if they have a pump or not
  • 2,973 Answers
Firstly, till you solve this problem, start watering the petunias manually else they may not survive. Just sprinkle a little bit of water on each pot.
Secondly, is the water flowing with a water pump or just by gravity? If by pump then check the pump if it is pumping water right. If by gravity then check if the water channel is blocked or choked.
Posted on Oct 11, 2010
  • Rinoo Kumari Oct 11, 2010
    No idea if there are pumps used to water the aerogardens. I thought that if the thing is large then it may have a pump to ensure that water reaches every pot.
HOW DO I UNFREEZE MY WATER HEATER I HAVE KEPT THE DOOR OPEN AND A SMALL HEATER IN FRONT OF IT BUT IT MAKES NOISE BUT NO WATER FLOW YET
it is probably not the water heater that is frozen but pipes in the area. Close the door leave the electric heater on and open a valve to let water trickle when it starts to flow.feel the pipe on the hot side of the heater if it is warm it is not the heater. try to stop any drafts and you can use a hairdryer to try to warm pipes that you think might be frozen. a torch will also work if you know how to use one and avoid any flammable areas.
Jan 17, 2015 | Water Water Heaters
My Whirlpool Duet washer is making a loud squealing noise when filling with cold water, and/or the water is reduced to barely a trickle. It does not make the noise/reduce cold water flow every time.
Hi.
Try to remove the sand filter(s) from the inlet hose. Both on the valve and on the water crane(tap) end. Common problem.
Usually this is the problem, but not always.
/ Geir
Technical Engineer
Sep 27, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water does not flow
Sounds like air in the line.....the filter may be cracked/damaged, or not quite seated...?
since you've tried 2 new ones....I'm gonna bet they are not quite the correct ones for your fridge.
Sep 07, 2012 | GE GSHF5KGXBB (254 cu ft) Side by Side...
I have a Hozelock super cascade 100 pump for a small pond. The water flow is very poor and I have cleaned the filter. I believe the pump is about 10 yrs old, is there anything I can do?
You need to put a vacuum gauge on it and see what the vacuum is. There are ways to increase the vacuum pull. You can shim the impeller closer to the volute casing, get it as close as possible without rubbing each other. If the parts are extremely worn, you may have to replace them. What about your pump seal? Is it leaking water? You could be sucking air in there, this would decrease your suction as well. Good luck.
Jun 18, 2011 | Garden
White apids on petunia plants how do I get rid of them???
soapy water in a spray bottle or you can buy aphid spray
Jun 14, 2010 | Garden
Just bought aerogrow kit but it has no instructions - how do I use it?
you will love Aero grow,I have three and they are in use all the time.
call them they will get you all you need!
1 800 476 9669
www.aerogrow.com
www.customerservice@aerogrow.com
www.aerogrow.com/help
these are good people .
I could tell you how to use this but there are so many varaibles depending on what plants you want its best to deal with them directally
Nov 07, 2009 | Aerogrow Classic AeroGarden Indoor Garden,...
Rinse cycle water flows out to a trickle- regular wash cycle flows normal- water valve?
Flows out where , drain or into machine ? If into machine , Most washers have a cold rinse into machine . If your using hot fill and you get a trickle , then problem is a clogged screen at the valve or a bad water valve .
Jul 06, 2009 | Washing Machines
Water will only trickle to fill ip washer. Is it
Most likely its the inlet hose or hose screen.
If water pressure is standard at all other areas in home secure 4 Hose washers at any lowes ace hardware or garden supply that sells garden hoses. Remove your hoses and place the ends in the basket and turn on the water. If you get a good flow out then look at the water valve inlet behind the washer. If its clean put on the new washers and retry it. Be sure to run the valve wide open a couple of times to flush out any mud or sediment before deciding the inlet is clear. sometimes the old galvanized pipes can be plugged up with rust. If the water is trickeling in and it is suppose to be on then it is not the solonid valve because its trickeling in not flowing. Let me know if this trick works and \please ratem me as high as you can. Thanks for using FIXYA and good luck.
Apr 06, 2009 | Washing Machines
Motor stopped
Go to the aerogrow aerogarden website they have step by step instructions on how to fix this problem. I had the same problem and was able to fix it by following the steps outlined there. http://www.hydroponicgardens.net
Mar 20, 2009 | Aerogrow AeroGarden
Aerogrow AeroGarden Logo
160 people viewed this question
Top Aerogrow Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Aerogrow Garden Expert? Answer questions, earn points and help others
