Question about Soleus KFR-24G Air Conditioner
Soleus kfr 24000 need replacement blower wheel
  • 86 Answers
SOURCE: soleus kfr 18gwda
outdoor fan motor burn or capacitor of fan motor defective,change the capacitor of fan motor,c the fan motor ok or not.its burn due to high voltage n low voltage.if the unit run with low voltage then it is harm full for all major n minor spare parts,use proper earthing,check voltage,voltage stabilizer.
Posted on Mar 15, 2008
  • 9 Answers
SOURCE: Soleus KFR-18 Air Conditioner Problem
All of the kfr series have a indoor coil sensor that monitors the tube temperature. In the heating mode it will sense for high temp and cut off the outdoor fan to try to lower the indoor coil temp. The cut off temp is 129f, when the coil cools down the fan will cut in and start developing heat again. If the coil continues to get warmer it will shut off completely. The system is either overcharged or the coils and or filters are dirty. All Soleus units need both lines insulated seperately and not together because the metering device is in the outdoor unit. Have your tech calibrate the charge and make sure you clean your filters every 3 months. Removing the sensor will cause the indoor coil to get too hot and possibley start to melt your housing. For further technical questions pleas call 626-378-1518 for technical questions,,professionals only.
Phil
Soleus Tech Support
Posted on Mar 13, 2009
Richie_asg1
  • 1036 Answers
SOURCE: blower wheel
This is how manufacturers are making more money - by tightening release of spares.
If you can't get spares without jumping through their hoops, try looking for these spares online. You might find a supplier in China with no problem supplying you.
Best of luck.
Posted on May 07, 2010
  • 449 Answers
SOURCE: my Soleus KFR-18GW Split
Check your thermostsat see if there is a fan switch on it set it to auto
Posted on Aug 19, 2010
  • 794 Answers
SOURCE: I need to purchase a fan motor and cross flow fan
Hi jj_colvin,
Please try to contact repairclinic.com. They do have large selection of airconditioner parts. Once you call just provide them the brand and model of your air conditioner and they will assist you in finding the exact part or the cross reference. You may reach them at 1-800-269-2609, 8 am to midnight ET, 7 days a week.
Hope this helps.
Thank you for using FixYa.
Posted on Sep 22, 2011
I need to know to do after changing the batteries in my remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Jun 02, 2014 | Soleus Air P-KFR09-05-ID Remote Control...
When i change the batteries the remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
After battery change, it should be set up with set-up codes to your device again. Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Soleus 14000 btu air 12000 btu heat
Hi
Your text "will not blow out" indicates lack of air flow.
There are two posiblilities:
The upper blower wheel has failed (evaporator coil) OR the lower blower wheel has disintegrated (condenser coil in cooling mode) - which is very common on this Soleus Air model. The blower motors are very good and rarely fail.
Unplug from outlet, remove the six phillips head screws which secure the back to front of the appliance. Look for many broken pieces of your blower wheel.The proceed to www.soleusparts.com and order a blower wheel replacement kit(s).
Problem solved!
Jun 17, 2010 | Soleus LX-140 Portable Air Conditioner
My unit turns on and blows for a minute, then stops blowing.
you need to call a service man. Your transformer, blower motor or wiring is probably melting.
Aug 11, 2009 | Soleus KFR-18GW Split System Air...
Soleus air heat pump soleus lx 140 quit working
Hi
The Soleus Air condenser blower wheel is all plastic and I have seen many of them disintegrate from normal residential use. It's just a weak part.
Go to shop.soleusparts.com and buy a metal blower wheel replacement kit. Problem solved!
May 19, 2009 | Soleus LX-140 Portable Air Conditioner
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Check your thermostat settings at heat mode.
Jan 03, 2008 | Soleus KFR-18 Air Conditioner
Soleus KFR-24G Air Conditioner Logo
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
