Question about Kitchen Ranges
Three out of the four simmerstats on our stove are not working correctly ie the all go to high heat with no control to lower heat. Where in Auckland can I find replacement simmerstats and at what price
  • 27 Answers
SOURCE: stove burner over heating on low setting
the element only does what it's told. more than likely the contacts in the switch are stuck. the switch needs to be replaced.
Posted on Nov 01, 2007
  • 136 Answers
SOURCE: Three of the four elements
just check out for the electric wiring diagram of your device given in this link for better help
http://www.applianceaid.com/image/microflowchart.JPG
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
on the fixya home page there is column called REPAIR SERVICEjust select the appliance category and enter the proper zip code of your area and the list of reparing person will be given with their phone numbers.you can just call them.
thanks.
Posted on Oct 13, 2008
  • 22 Answers
SOURCE: power working but burners and stove doesnt
Sorry brother, the board is fried.
Posted on Dec 25, 2009
EllaWatson25
  • 725 Answers
SOURCE: my stove has anF-1 code, I was told i need a new control panel
You can find them through us!
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
  • 52 Answers
SOURCE: Stove top radiant heat burners don't regulate properly
We also have the same problem with the JS968SOK1SS and it is driving the wife crazy since it ruins many recipes that call for even heat.
As she said "It is crazy her electric skillet regulates heat better than her GE range"
I've been telling her Gas is the way. Has anyone found a solution to this problem or is that to be expected of Electric ranges?
Posted on Feb 06, 2011
Three of the four stove stop heating elements thermostate doesnt work. It is either on fully or have to turn off to manage heat. remedy ?
Hi, You will have to replace the switch with a new one. That is all that is needed . Good luck.
Jan 12, 2016 | Dryers
I have a Simpson Neptune stove 2U602W which needs new simmerstats.
If the connectors are in the same pattern, you can ignore the numbers and go by the position of the connectors, so top left on the old, would go to top left on the new.
You could ask the maker direct.
http://www.simpson.co.nz/SupportCentre
Sep 13, 2015 | Ovens
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
Spectra profile performance jb960k0d1cc has power but neither oven and stove work
what type of power cord does your range have? is it a three prong cord or a four pronge cord. If it is a four pronge cord you must make sure that the ground wire is attached correctly on the back of the range. You can refere to your owners manual that came with the range on how to hook up the range cord.
Nov 14, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
Stove plates have three settings. High, med, low.
60 years old . quite possibly not worth fixing .
Mar 05, 2017 | GE Cooktops
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
Stove top elements on high only
Yarsu Spiros
I like you purchased one of these thinking you can trust the name simpson(pope) but after putting on a fry pan with sum saucages in and having a major fire in my kitchen, I through the heap of junk out and bought a *** oven (current technologie) howerver to answer your question you have pulled the elements and trays out to kleen them (that seems normal) but you need to make sure the element terminals are clean and so are the spring clip things they fit into, use a peice of emery cloth (not wet & dry) this should fix it
alternativly not buy this junk again and get a proper stove
regards Graeme
Auckland NZ
Jan 02, 2009 | Kitchen Ranges
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
