Question about Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range
Can you convert this oven from natural gas to propane?
Yes - I believe it comes with the new jets that you need to change out. Not that hard to do really; we did it ourselves.
Posted on Aug 06, 2011
4 Suggested Answers
SOURCE: Convert natural gas range to propane
I want
Posted on Jun 09, 2008
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
Posted on Jan 29, 2009
lscf150
  • 443 Answers
SOURCE: LP conversion
If you can turn a wrench you will be able to do the conversion yourself, just about all gas ranges come with the LP conversion kit attached to the back of the range usually around the gas regulator but sometimes it can be anywhere on the back, and the your owners manual has step by step instructions on how to do the conversion. Good luck !
Posted on Jan 05, 2010
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
FLAMES TO HIGH IN OVEN G E GAS RANGE
Are you on propane (LPG) or natural gas? If on propane, then the oven has not been converted to propane properly.
Sep 10, 2014 | Kitchen Ranges
The oven flame comes into the oven around the oven bake cover and all burners and broiler have a perfect flame. this is a brand new oven
Are you on natural gas or propane? If you are on propane did you have it converted form natural gas. Due to the difference in orface size you will be getting more gas flow then needed. If it was converted you need to contact the store and advise them it has a possible gas valve problem.
Jun 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
Stove converted from natural gas to propane burners work fine but oven has about 8'' of yellow flame and comes up over diverter into oven. air shutter makes no difference full open or full close and...
The orifice, holes that the gas comes out to the burner)s) for the oven was not changed out.Gas is measured in inches, Natural gas runs abourt 5-7 inches of presure, Ppropane runs about 12-15 inches of pressure, much more. The orifices, holes that the gas comes out, for natural gas, are larger to send more gas to burner. With propane, the orifices are WAY smaller, because the pressure is much higher.
Mar 30, 2010 | Kitchen Ranges
Switched from natural gas to propane now oven flames up sides how do I fix? Model#362.75571691
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
Please be careful
Jan 01, 2010 | Kenmore Kitchen Ranges
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas Oven, lights and terrable smell, and flame shoot out
yea sounds like you have a stive set for natural gas hooked up to propane gasm you need to convert that thing instructions are simple to follow in installation manual, or if you paid someone for installation id get them back
Feb 28, 2008 | Kitchen Ranges
Frigidaire fgf316wgsh
Is it natural gas or propane? They usually come as natural gas. If it is propane has it ever been converted? If not convert it.
Nov 30, 2007 | Frigidaire FGF316 Gas Kitchen Range
Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
