Question about Sylvania Televison & Video
We have a Sylvania TV. Basic simple TV....older. We need to get a DVD to play. We have hooked up yellow and white cables but it won't work on channel 3 with game mode on or off. Help!
    Sergeant:
    Champion:
  • 387 Answers
Try to switch to video mode on the TV
Posted on Oct 11, 2010
The converter box is hooked On the TV and working. I have the TV with the rabbit ears and only video n audio in the front (yellow n white). I recently purchase a DVD player n I am trying to hook it on the...
you have to change the input on the tv to AV. there should be an input button on the remote, but if your remote doesnt work you might not be able to change the input. you can try to use the channel up and down on the tv and once you get to the end of the numbers, some tvs will change inputs before restarting the number list. make sure you hook the yellow cable to the yellow plugs on the dvd and the tv and either of the red or white ones to the white one on the tv. red and white are left and right audio and the yellow one is the video
Dec 24, 2010 | Insignia Digital-to-Analog Converter for...
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
I have an old DVD player from 2002 & I'm trying to hook it up to my TV (old TV too). Do you have a graphic of the hook up? The TV has a spot to hook up my cable for my basic cable channels. The DVD...
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Feb 07, 2010 | Toshiba SD-2800 DVD Player
Magnavox dv220mw9 does not have a ant. in,or ant. out. How do I hook up to my direct tv satellite rcvr. My original hook up is from a DTV d10-300 RCVR to a Sylvania vcr/dvd SR2900,which has a antenna in...
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd player2.gifto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Jun 04, 2009 | Philips Magnavox DVD/VCR Dual Player
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
Trying to get ps2 to play on new tv..
USE a VCR between the PS2 and the Sylvania TV.  Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4.  Set the VCR channel to Line 1 or Line 2.  This should work. I hope it helps you.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
Televison & Video Logo
257 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
