Question about Eten Glofiish X500 GPS Pocket PC
Cannot connect to internet
I have an X500+. It can find networks and connect to them but when i put a url into IE i get an invalid address response. I have tried this with different routers and all have the same problem. I can also confirm that all the routers do indeed have internet connectivity as laptops on the same networks were working.
thanks
--t
  • 107 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 08, 2010
Motorola ex115 invalid url on opening internet
Hello Yashawant Pawar,
For this devices we have a specialist team that can definitely address your concern on this particular model, let me invite you to give us a ring to: 1-800-734-587.
Regards,
Lester S.
Motorola support
Oct 27, 2014 | Motorola Mobility EX115 Cell Phone
My mini sylvania laptop says connected to internet but Explorer browser will not connect
I would suggest that you click on the tools and options in IE and return all the settings to default. Also, clear the browser cache.
Then check the network connection to make sure your firewall is not blocking IE.
Oh, yes--then go to IE and try to navigate to Google. Perhaps the URL in the address box is bad.
Oct 11, 2011 | Sylvania G-Netbook
Invalid url
Hi ganibanto,
I see that you are getting an Invalid URL on your system.
Have you tried resetting your IP address? you can reset IP address only if you have a wired internet connection meaning if you are using an ethernet cable to connect to the internet.
If you are using wireless, then you will have to mayber reconfigure the wireless settings on your system possibly uninstalling then reinstalling the wireless drivers of your woreless card or maybe you can just delete the wireless network you have on the system then recreated the wireless conenction again by detecting the Router from your Computer and re-entering the details of your wireless network like wireless network security and the SSID info.
I hope this helps.
Have a nice day,
mvincent
Jun 01, 2011 | Computers & Internet
I want to unblock the facebook sites
There will be an option on the router's web configuration page called URL blocking or web filtering. Your can unblock it from there. For accessing the router's web configuration page you have to type the default gateway on the brower's address bar. Your can your IE or Firefox.
Steps to find the default gateway
Start->Control panel->network and internet connections->network connection-> Right click Local area connection-> Status->Support
This will show you the default gateway something like 192.168.1.1
The open Internet explorer type 192.168.1.1 on address bar and unblock the facebook
Aug 17, 2010 | Computers & Internet
192.168.0.30 for DWL G710 does not respond
hi r_raiche
1. Take a regular ethernet cable and plug it into the ethernet port of your computer
2. Plug the other end into ethernet port of the DWL-710
3. On your computer (assuming you have Windows XP Pro with the NON-classic start menu), go to Start > My Network Places
4. On the top left under "Network Tasks" click on "View Network Connections"
5. Right click on "Local Area Connection" and then down to "Properties"
6. A pop-up window with 3 tabs should come up. Under the "General" tab, there is a list of icons with checkmarks next to them. Highlight the "Internet Protocol TCP/IP" on and click the "Properties" button underneath
7. Tick "Obtain an IP address automatically" and "Obtain DNS server address automatically"
8. Click on "OK" then "OK" again
9. Open up Firefox (or IE) and type 192.168.0.30 into the URL field
10. Type in the default username and password
Jul 07, 2010 | D-Link AirPlus G Wireless Range Extender...
Cannot connect to the internet wirelessly. says i
If you are getting invalid ip try the following:
  1. Click Start and type "cmd" in search press enter
  2. In the command prompt window type ipconfig /all
  3. Check the ipv4 ip address
  4. If you are getting an ip address as 169.254.xxx.xxx
  5. Go to device manager
  6. Uninstall the Network Adapter
  7. Reboot the computer
  8. Re install the driver for you network adapter if prompted
  9. You should be able to get a Valid ip address and get connected
If you have a pci network card installed
Try to remove the card and install it in another slot.
Hope you find this solution helpful.
Thank you for choosing Fixya.
Jan 22, 2010 | Acer 91.AB370.001 Network Adapter
Cannot connect to open wireless network Invalid IP Address
Either the network requires you to manually configure your ip settings(unusual but not unheard of) or your wireless adapter is not set to get settings from DHCP. Check to verify that your wireless adapter is set for DHCP and if this is correct then you'll need to contact the administrator for the wireless AP and haver them check their settings.
Jan 08, 2010 | Dell Latitude D610 Notebook
Need to disable the access of the address bar in IE
hi,
You can use frames to keep your URL fixed while still allowing navigation without revealing the actual URL.
Example: http://www.rgagnon.com/jsdetails/js-0099.html
Alternatively, As your real intention is to prevent users from modifying the URL, consider implementing URL rewriting to scramble the URL so that the actual file path is not obvious. URL rewriting is the process of intercepting an incoming Web request and automatically redirecting it to a different URL.
Check these links for more info on URL rewriting:
http://msdn2.microsoft.com/en-us/library/ms972974.aspx
http://www.aspnetworld.com/articles/2004011901.aspx
Apr 27, 2009 | Microsoft Windows 95 + Internet Explorer...
Palm wifi url connection
This can happen if the wireless network you're trying to connect to is password protected. If you can see the name of the Wi-Fi network you're trying to connect to and there is a padlock symbol next to the name then you'll have to enter the WEP or WPA-PSK security keys. If this is not the case and this is your home wireless system which is unprotected then I suspect what's going on is that you may need to enter a DNS server number for your network on the Palm. To do this, select a wi-fi network you're trying to connect to, click edit, choose "configure", click on "Details". Where it says "Connect to:" select "infrastructure" then click on the "Advanced..." buttton. Try putting in the DNS server number manually for your internet service provider.
Nov 02, 2007 | Palm TX Handheld
Eten Glofiish X500 GPS Pocket PC Logo
136 people viewed this question
Top Eten Computers & Internet Experts
David Payne
David Payne
Are you an Eten Computer and Internet Expert? Answer questions, earn points and help others
