Question about Sony Playstation 3 (PS3) Console
My ps3 wont play blu ray disc - Sony Playstation 3 (PS3) Console
  • 358 Answers
The most common reason for the Wii not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!!!!!!!
Take care.
Posted on Oct 11, 2010
  • jersey mark
    jersey mark Oct 11, 2010
    Hi, sorry that did not help. You’re going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you’ll be familiar with the entire process. First take off the outer cover of you PS3. If you haven’t done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover. {mos_sb_discuss:18}
    To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small Phillips screwdriver (I’ve seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
    After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
    This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you’ve toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you’re finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you’ve found the proper angle and the system is operating to its full potential, close it up and letter rip. I also do not recommend placing the PS3 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
    Hope this helps.
3 Suggested Answers
  • 12 Answers
SOURCE: all rgion code for ps3 (india)
dvds from different countries donot work on a home bought ps3
Posted on Jun 05, 2009
SOURCE: why wont predators blu ray play on my ps3. all of
go to your ps3 BD data utilites under video and delete the storage you have from the previuos discs you have played. I HAD THE SAME PROBLEM AND SFTER FOLLOWING THIS STEP THE PREDATORS DISC WORKED FINE.
Posted on Oct 24, 2010
Why wont predators blu ray play on my ps3. all of my other blu ray discs will play but predators wont. the screen says tat the blu ray needs to be updated
Oct 23, 2010 | Sony Playstation 3 (PS3) Console
Blu-Ray disc player model: BD-HP21H
You will need a 2GB usb device a.k.a. a flash drive. You will need access to the sharp web site. You can call 800-237-4277 any time between 9AM-7PM CST today or 7AM-7PM tomorrow to be walked through the software update you need from start to finish.
May 31, 2010 | Sharp AQUOS Blu-ray Disc Player
My new 3.15 ps3 won't play blu-ray but will play everything else no problem. no problems to play games or to play normal dvd's. When playing a blu-ray the UNIVERSAL part at the start of the movie plays...
f the Blu-ray Disc does not support 1080p 24Hz video mode, the video output may not display properly.
If a Blu-ray Disc movie is not loading properly or is freezing on a title screen, this may be caused by the PLAYSTATION 3 attempting to download BD-Live content from congested movie studio servers. If you experience this issue, you may choose to temporarily bypass the BD-Live content until the congestion at the movie studio servers has cleared.
Go to Settings icon (Settings) > Video Settings icon (Video Settings) > [BD Internet Connection], select "Confirm". Then reload the Blu-ray movie and the PLAYSTATION 3 will prompt you if you wish to allow the disc to access BD-Live content. Choose to not access BD-Live content to see if the movie will now load.
For some reason you seem to think this is a PS3 problem. Why do you think this is a PS3 problem? If you can play PS3 games, then I will say it is not a PS3 problem, as all PS3 games are on Blu-ray, and if you were having problems playing PS3 games, then that could account for the movie not working.
Since only the movie isn't working, I am going to say you have a defective Blu-ray disc. Did you just buy this movie, or have you viewed it before using the PS3? If you have never viewed it on the PS3, then the problem lies in the disc, and you need to take it back and have it exchanged.
If you have played the disc in the PS3 before (the PS3 you are having a problem with, not a different PS3 or Blu-ray player), or you still think it is a PS3 problem, then use the "Disc Troubleshooting" support page. Normally, if a Blu-ray movie will not play, it won't play at all, and it is because the Blu-ray laser has gone out. It sounds to me that the disc is bad, but this is only going on the information you have supplied.
Here is the Disc Troubleshooting support page mentioned above:http://playstation.custhelp.com/app/answ…
**EDIT**
Sorry, I just noticed you gave a UK link. Here is the support page for the UK. You will have to do a search on the site to find the Disc Troubleshooting page for your region.http://uk.playstation.com/support/
**EDIT**
Okay, here is your Disc Troubleshooting page for the UK:http://faq.en.playstation.com/cgi-bin/sc…
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont play region A Blu Ray disc?
have you confirmed if your ps3 is manufactured to play region A discs?it might be configured to play region B discs.
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
Ps3
try setting the console back to factory settings, i had the oposite problem, would play games but not movies. will it play blu-ray movies or regular? if it doesnt play blu-rays, your disc reader may have gone bad.
Sep 22, 2009 | Video Game Consoles & Games
PS3 wont play discs
Your blu-ray laser needs replacing.
We offer this service at a competitive proce.
FixMyConsole
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
My ps3?
does it play blu ray discs? if not its the blu ray lens thats packed up, phone sony and as long as its less than a year old they should fix it, if older than year they will probaly charge for it.
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
PS3 wont read discs
Me too dude, down right disturbing. We are all getting F-ed!!!!
have an 80 gig machine, downloaded the aptch, played 1 game of CoD and it froze. WTF!!!
Apr 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
321 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
