Question about GE JVM1850 1000 Watts Microwave Oven
We used the time cook versus timer and ran the oven for about 20 min's with nothing in the oven. Now the Microwave dead, no display, unpluged and replug. Let it set till cool. Check Circut breakers - all good. Dead Microwave?
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 11, 2010
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
Will running the GE profile JE1860sb 001 with nothing in it destroy the magnetron
no the big fuse has gone usually 10 amp bigger china body fuse
so get the right bits
has no display so no power
i think your microwave oven
may have a fault in a thing called the diffuser plate
its a square or rectangle of mica a mineral
its used to scatter the waves around the oven for even cooking
it can develop carbon tracking as it changes state
so shorts out the energy to the body of the oven and can eventually blow the fuse as fuses become tired from surges of used energy
or some part of it has a problem exposing some metal parts not earthed to the chassis
magnatrons are the best actual valves every made
almost indestructable other than the heater element {inside the square end metal can is its connections usually welded {dont try to solder them}
so no the magnitron is aok
look for another reason
usually replacing the fuse and defuser and a good clean perhaps sometimes its the plate rotation drive motor plastic drive part
also becomes carbon tracking
causes the same error
good luck
note for all ::
next time buy a stainless steel microwave
from a good maker
and good parts supply of defuser plates as they do go wrong
Dec 21, 2014 | GE Microwave Ovens
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Husband thought he set the timer but actually ran the over for 35 min. This was really hot and now looks dead. No displays, nothing.
Yes, you are probably right... he killed it... :-(
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 16, 2010 | Jenn-Air JMV8208AAS Microwave Oven
Unit is dead after accidentally running it empty.
If you ran it for that long with nothing inside, there is a good chance it self cooked.
It can probably be repaired. The economics of the repair is something you will have to judge for yourself.
To assist you, may i suggest you visit www.repairclinic.com and check on some major parts for your make and model. If the parts = more than 25% of replacement, I think id be moving on. Expect to pay a pro at least $100.00/hr labor. You should NOT do it unless you are skilled at handling delicate and lethal electronics. A microwave can kill. Another thing, after you fix it, you have a lot of $ invested and still have a old machine that ran for 13 + minutes empty.
Oct 13, 2009 | Microwave Ovens
My microwave has 00:00 where the time or cooking mins should be displayed. I am pushing buttons and nothing changes. I can't use the microwave.
Unplug the microwave for 10 minutes and then replug-in. This will reset the unit.after that if it still behaves abnormally , Press cancel button for 10 seconds and then try pressing the timer adjust buttons.
thanks
Aug 31, 2009 | Sharp Microwave Ovens
Oven won't function after 5 minutes of cook time with nothing in
It's posible that since it was running empty, the magnetron overheated and a thermal cutout or thermostat located on the magnetron opened.
Magnetrons may be protected by a thermostat, which will reset when it cools, or a thermal fuse, which is a one-time use device. It is also possible that in some cases, a thermostat will fail when opened.
In the worst case the magnetron may be damaged due to running empty.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 07, 2009 | LG LMV1630 Convection/Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
259 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
