Question about Kenmore HE2 Plus Front Load Washer
Remains locked, doesn't drain, and has F21 displayed. Weird sound.
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
The "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, hence the weird noise...although a faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...
Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation.
If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way.
Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 11, 2010
  • 3 more comments
  • Jozzy Oct 16, 2010
    This was PERFECT!!!! I had my finger on the buy button for a pump and pressure switch. Now I have one more thing to verify before I spend over 100 bucks! THANK YOU!!
  • Mark MacDonald
    Mark MacDonald Oct 17, 2010
    Awesome. Glad you found my solution helpful.
    Thanks for checking us out here at FixYa.com Spread the word.
    Regards,
    Macmarkus :)
  • Handy787 Oct 19, 2010
    I thought I needed a motor control unit, but cleaning out the filter (and removing a small sock from it) did the trick. Thanks for the excellent solution.
  • Mark MacDonald
    Mark MacDonald Oct 19, 2010
    Awesome. Glad you found my solution helpful. Thanks for checking us out here at FixYa.com Spread the word. Regards, Macmarkus :)
  • Ann Kankaanpaa Mar 21, 2011
    Thanks so much for the information on this site! I have a washer that is washing as we speak! Made our families week. Nothing like doing laundry at home.
    Many Blessings and Much Peace Your Way!
    Annabananna of Arizona
Washer code is f21
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Sep 20, 2011 | Kenmore HE2 Plus Front Load Washer
I am getting a code F21 it stops about 15 min through a cycle
Hi
Daniel
Sep 15, 2011 | Kenmore Elite HE5t Washer
I have a siemens washing machine that says f21 what does that mean
Many thanks. For F21 fault everyone was talking about the drain valve but found one answer related to power supply n board this helped. Resetting by turning program switch to 12 o clock then turn to 6 o click then keep spin button pressed n move knob to 7 o clock position. Then release spin n move knob to 12 o clock. This way F21 got resetted.
Aug 31, 2011 | Washing Machines
I have cleaned out the washer and cleaned the filter for the f21 code .i tried to restart washer with nothing in it and it washed for a minute the stopped and flashed 5d again what can i do?
Hi
Daniel
Aug 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is not spinning or draining it keeps flashing F21
Hi
Daniel
Aug 24, 2011 | Kenmore HE2 Plus Front Load Washer
Model WFW9600TA01 - error messages SUD, F21 and F22 keep coming up. machine has not been used for 2 weeks.
Hi
F22 error is a door lock error, if you have already replaced the complete door lock assembly and the issues is still there then check the wire harness connections to the door switch/lock Unit and Central Control Unit (CCU). If the wire harness is fine then the issue is with CCU that should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 15, 2011 | Whirlpool Washing Machines
What does an F21 error message mean in a Maytag 5000 series front load washer>
Hi
Daniel
Aug 15, 2011 | Maytag Washing Machines
F21 code appears on washer, water will not drain from basin of washer. need to order drain pump
Hi
Daniel
Aug 09, 2011 | Kenmore Elite HE5t Washer
My Kenmore HE2 Plus wont start and it gives code F-21...... the door locks but the washer wont fill up with water.. then it faults out. What can I do?
Hi
Daniel
Aug 06, 2011 | Kenmore HE2 Plus Front Load Washer
F21 error on kenmore he2plus washmachine. Door locks. Due to no spinning and water remaining in the machine? I run the rinse/drain&spin program (15 minutes) several times. it stays at 15min remaining...
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 23, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
393 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
