Question about Soyo P4I Fire DRAGON i845 Chipset Socket 478 MBB (MBBSYP4I) Motherboard
Cheebs i want to download up grad new version bios . my motherboard manli
    Genius:
  • 1,847 Answers
Try this link
http://www.bios-drivers.com/companies/1332.htm
Hope it will help.
Posted on May 31, 2008
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
How to update bios
hello f_franco32
to update the bios on this motherboard go to asus web site
www.asus.com
one on asus web site go to services ---> support -----> download
at the top left hand corner type in your motherboard model P5PE-VM, under that in select category selct Bios,
chhose your operating system from when the question pops up. (does not make any difference which windows version you choose. Bios in independent of your operating system.)
download the version of bios you want. the bios you download will have the utility with it but just in case it does not, download the bios utility as well.
format a floppy and make it bootable. copy the bios files to it. start the computer from the floppy and update your bios.
when you boot from the floppy at the command prompt you need to type in the utility name "Afudos" follows by the new bios name.
you can also do this using a bootable flash drive.
hope this was helpful.
please vote for me
Jan 02, 2011 | ASUS P5PE-VM Motherboard
BIOS update on MSI KT6 Delta (MS-6590 v2 5.0)
You should be able to get it from here.
http://www.motherboard.cz/driver/msi.htm
Apr 26, 2010 | MSI Microstar KT6 Delta (MS-6590)...
When i go to install OS, it shows that bios isn't acpi compliant
This errror coming from motherboard because your BIOS version is different as compare with new version, so download new BIOS for ASUS Intel 815E Chipset CUSL2-C from web site of ASUS there is detailed step of How to upgrade BIOS, you can upgrade BIOS by creating Bootble Disc otherwise you can Upgrade from OS.
I hope that this has been very helpful for you
Dec 12, 2009 | ASUS Intel 815E Chipset CUSL2-C...
I need bios version 3.0 for motherboard A8M2N-LA,GL-6
Hello, go here this is the only place I found the 3.0 version. scroll down on the website fill in your mail address and get a download link to your email.
"You can create a new account for free. Members have unlimited access to all files.
If you want to download only this one file, we will send a download link to your e-mail."
Aug 17, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Motherboard driver
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-
Apr 25, 2008 | Intel Motherboard
Bios flashing
you have few ways.one the clasic one.download a new version of bios,make a bootable floppy or cd and in dos mode rewrite the new bios.
-you can put it on  a syick and make it bootable
-if supported by your actual bios as an option flash it using this bios option
-you can also update it by using some software specific from your motherboard instalation cd.
everyway you choose be carefull.flasing or updating the bios is a very delicate operation and can severly damage your board.
so if you are not sure you can do it better talk to someone who did it several times before  and let him do it.
good luck
bye
Feb 05, 2008 | Intel Motherboard
Computers & Internet Logo
59 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
