Question about Intel Motherboard
YESS!!! but... there is life!!! lights and everything! but nothing on screen! the light on the monitor is flashing.... seen it like that before actually... but don't know how to sort it... is it to do with static??
    Scholar:
  • 187 Answers
Check my reply to your other post :)
Posted on May 31, 2008
Hey my hp g70 was working fine like beast but suddenly screen whent off i tried everthing unplug inverter and put it back every other thing that i can do but nothing happend when ever i press power button...
If another device worked plugged into your laptop then either the screen is bogus or the part of your computer that powers the screen is fubar. Take your choice. Screen less expensive to replace than the mo bo.
Sep 15, 2017 | HP G70-460US Notebook
I have a XPS M1530 the screen is black I press the power button for a second it stay on everything lights up sounds and feels like its on gets warm but nothing on the screen Itrying everything taking out...
You either have a Video Card problem or an issue with your LCD Screen.
Does it every post anything to the screen? If nothing ever posts on the screen when you hit the power button and it will not do anything with an external monitor, then your Video Card is bad. I wonder if you have the Nvidia Graphics Video card on your system?
If it seems like the laptop booted up all the way (you hear fans running, hard drive spinning, see lights) but the screen is black then try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 16, 2012 | Dell Computers & Internet
Dv9220us video is not working!!
well your Display is dead, internal if the key stroke below fails.
this PC is HP retired status now, no docs, or support.
what OS, XP
did you press fn+F4 key and set the screen setting to both?>
so both screens run at same time.
if the screen is dead in BIOS (you said nothing that means no text ever shows up, like hit esc key to enter bios" is gone.
next is what the flash light trick pointed add screen see words now?
yes, bad backlight, CCFL lamps? or bad back lamp inverter
do this yet. (if you see data, then LCD id good, and is a dead back lamp. all old LCD do this at 20k hours life, span.
http://pcdied.com/monitors.html#flashlighttest
fix that our use an external screen for the remainder of its short life.
its old, so, use up the "remaining life"
Aug 21, 2017 | HP Pavilion dv9220us Notebook
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
Flashing light nothing else
Doesn't sound like a virus. Sounds like a fuse or something else is out. A red light isn't good. If the monitor is ok you get an amber light. I would suggest this monitor is gone. Sorry.
Jul 20, 2009 | Envision EN9410 19" Flat Panel LCD Monitor
Rplaced power unit now the monitor will not come up with anything on it. Orange light blinking on front of cpu.
Make sure your monitor is connected to the proper video connection- that is if you have a video card in your machine and a video connection on your motherboard. If you connected to the motherboard and you have a video card -your screen will show nothing even though you are powered up. Dont know your situation, but just checking. Ive seen others do this.
Char S.
May 20, 2009 | Sony VAIO VGC-RB53 PC Desktop
Monitor shows nothing on screen, power button on solid, none of other buttons respond.
plz try by removing the connector of the monitor from the back of cpu while keeping your monitor power on. if you get any message in the monitor then your monitor is ok. then open your side cover and try by resiting the ram, you have to swithch off your pc before opening your side cover. If you dont get any thing in the monitor then *********** board is having problem
Apr 13, 2009 | Computers & Internet
Acer AL 1715 monitor flashes 2x and dies
LCD panels use cold-cathode fluorescent bulbs to make the light necessary for them to show images. What you're describing is something I've seen in panels where the bulbs were dying or dead. it's also possible that the controller for the bulbs is also on the fritz.
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Intel Motherboard Logo
24 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
