Battery location where do i locate the system battery in a simon 3 wireless system? i havnt used the alarm for 2 years and want to use it. dont know the code and default numbers dont work but i have remotes to disarm and arm system. Problem is status low battery is on then alarm sets off due to movement sensors. i changed the batteries in the sensors but need to know locations of any other batteries please thanks ian
  • iani Jun 08, 2008
    yep found the battery under the control panel cover, it was a 6volt type about 4 inch by 2 inch by 1 inch
    sorted the problem with a new one
    thanks again
    ian
    Guru:
  • 859 Answers
First off, I am not intimately aware of your system. However, the battery that keeps settings and the Date and Time should be under the cover of your control panel. It looks about the size of a quarter or a bit smaller and about 5 millimeters or less thick. We all call these Button Batteries. Yours will have a number stampted on the +face such as 2027 They're easily found at either the grocery store or a Radio Shack. Cost about five bucks, usually.
That's about all I can say at this moment. If removing the cover to your control panel doesn't reveal the button battery, Please Let Me know and I'll be happy to get the schematic and let you know.
Regards,
Worldvet
Posted on Jun 02, 2008
  • Glenn Rogers
    Glenn Rogers Jun 08, 2008
    Great news.
    Thanks for using Fix Ya.
    Worldvet
How do I change the phone number that my GE Simon Security System calls when the alarm is triggered?
Open the front cover, enter the installer code and "add" the new phone number in "Option 4" as the Primary phone number. "Option 5" is the secondary phone number location on the Simon 3.
Aug 21, 2011 | GE Security Simon 3 Wireless Home Security...
Need to change a battery for a simon 3 wireless scurity system. any suggestions
It takesa 6VDC 1.2 AH battery. The battery is located in the back case.
AlarmProfessor.net
Jul 08, 2010 | GE Security Simon 3 Wireless Home Security...
Ge simon 2 alarm no longer beeps after battery replaced
Probably knocked off the clip on the piezo. Open the box and make sure all plugs are plugged into the circuit board.
AlarmProfessor.net
May 20, 2010 | GE Security Simon 3 Wireless Home Security...
Where is the battery located in the Simon system?
Hi.
The battery is located inside the Simon. Use a flat screwdriver to remove the panel.
Here an online manual.See page 23.
Connect the battery BEFORE connecting the power transformer.
Regards.
May 08, 2010 | GE Security Simon 3 Wireless Home Security...
Bouht a forclose home with a simon alarm in it but dont have the access code how do i fix this
1. disconnect the AC power ad the battery
2 . Opent the front panel
3. Depress Cancel, Set Time and Minutes+ keys all at the same time and plug in the transformer.
4. System says System XX OK.
5. Reconnect battery
System is defaulted, installer code is 4321 and master code is 1234
Alarmprofessor.net
May 06, 2010 | GE Security Simon 3 Wireless Home Security...
GE Simon says that the smoke alarm has a low battery. Replaced the batteries, and still receive the same alert. ???
I know some of this sounds obvious but the problem is usally related to 1 of 3 things.
1 Battery oreintation is wrong
2 Replacement batteries were old and were already below the low battery threshold (1.35 volts per battery/ 2.7 volts combined)
3 Didn't use the correct battery - manufacturer recommends lithium batteries (quality alkilines will work but they will have a shorter life)
Beyond this I will need more information to diagnose the issue.
Mar 19, 2010 | GE Security Simon 3 Wireless Home Security...
Battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
Sep 20, 2009 | GE Security Simon 3 Wireless Home Security...
Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Aug 11, 2009 | GE Security Simon 3 Wireless Home Security...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
