Question about Element Electronics ELCHW261 26 in. TV
Trying to find how to unlock input on element TV. Trying to hook up to DirectV and the input is locked and wants a password. Model ELCHW261, Serial no. RH900036280066394. Mfg date 08/2009.
  • th1938 Oct 11, 2010
    Duh, no we hadn't, but 0000 worked. Thanks a lot.
    President:
  • 2,777 Answers
Strange, have you tried 0000, 1234, 9999 as the codes? Is it a four digit code? It is very strange for a single input to be locked...
Let me know
Thanks
Tim
Posted on Oct 11, 2010
  • Tim Grayson
    Tim Grayson Oct 11, 2010
    My pleasure! If possible please come back to the question here and click the Accept
    This Solution button, otherwise I don't get credit for the help
    provided.
    Thank you so much,
    Tim
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
Sep 02, 2015 | Emerson Televison & Video
Turn off widescreen on element elchw261 tv
Select menu in remote control, select format, change ratio size to fit your screen. If you do not know the correct format, you may have to try all the options.
Jul 04, 2012 | Element Electronics ELCHW261 26 in. TV
Can i program lg magic remote to work with direct tv box
If your LG TV came with the IR blaster cable you will need to set one of the sensors in front of the sensor on your DirecTV box. Then go to your TV setting and select Video Input and Select the Input Port that your DirecTV box is hooked to. (In my case HDMI1). Then you will select that you are trying to sync your Service Provider and it will give you a list of device manufacturers. Select DirecTV limited and it will start to give you codes to try. You test these by trying the channel button up or down. If the channel changes you have found your code and you will click on "Yes" and you are ready to control. The "Guide" button will now bring up the DirecTV Guide and you no longer need the DirecTV remote.
Jun 05, 2012 | LG Televison & Video
A few issues with my Element TV ELCHW261
If your computer TV card has a SV output,you can use that.You need an SV cord to go from the TV card to the TV,if the TV has an SV input,then select input video source on your tv to video 1 or video 2,depending on which video the SV input is on...good luck
Apr 12, 2010 | HP G70-250us Notebook
Where do i get a replacement lcd dcreen for a element 26 in. ELCHW261
Nowhere. If the lcd panel is busted it's cheaper to buy a new tv than fix to one you have.
Feb 03, 2010 | Element Electronics ELCHW261 26 in. TV
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
I have a Directv RC24 remote control. I am trying
Programming DIRECTV Remote
1. Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
6. Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
Element Electronics ELCHW261 26 in. TV Logo
769 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
