Question about Whirlpool Duet GHW9150P Front Load Washer
Light bar on far left is lit up in the control lock status and i cannot get it out of that status. i unplugged and plugged back in and still has "control lock" lit up
  • elkhunter123 Oct 11, 2010
    very helpful, i just went and held the button as instructed and problem is fixed. thankyou
    very quick and solution solved my problem. now i get to continue doing loads of wash throughout the night!! Yea for me!
  • 5,081 Answers
My dear friend this is an very common problem people do face with. Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Posted on Oct 11, 2010
  • INDIRA KUMAR
    INDIRA KUMAR Oct 11, 2010
    A helpful rating and an testimonial would be greatly appreciated if you are satisfied with the solution i have posted.
  • INDIRA KUMAR
    A testimonial from your side would be greatly appreciated if possible.
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
How to correct control locked will not go off on whirlpool ghw9150 washer
While the machine is 'on' press & hold the "end of cycle" button for 3 seconds, or till the lock light goes off. This is on the far left or right of the machine's panel. Good luck! Pl rate me.
Sep 01, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Control panel on front stops working, only freezer lights are lit, freezer and fridge stop cooling.
when half of the display goes out, it is giving you an error code telling you what is wrong with the fridge.Unplugging it simply resets the computer until the error comes back typically within a few hours.
without knowing what is lit up, it is difficult to help you so I would recommend putting the error code "which bars are lit up" in a comment so we can diagnose further
Feb 03, 2018 | LG LFX25960ST Stainless Steel French Door...
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
Modem light keeps blinking Have tried resetting. Restoring to default settings. If I hook the computer directly to the time warner modem I can acces the internet fine. Thanks
If the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
How to configure the router for Time Warner?
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
3.Under Internet Settings, change the connection type as Dynamic.
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 10 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
For any advanced help, revert asap!
Thanks and regards,
Arvind
Jul 04, 2010 | Belkin F5D8236-4 Router
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
lit, all buttons are disabled. You can lock the washer while it is
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Controls locked status light stays on and dryer cannot be used
To enable the control lock feature:
Press and hold the CYCLE SIGNAL button for 3 seconds. The
CONTROLS LOCKED icon lights up, and a single beep tone is
heard. To unlock, press and hold the CYCLE SIGNAL button for
3 seconds. The indicator light turns off.
Jul 11, 2009 | Dryers
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Control Locked light is on...
OMG!! I just held the button at the end of cycle signal for about 3 seconds and the light went off! Now my washer is working!
Ok Yankee
Nov 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
