Question about Kenmore Washing Machines
I have a 700 series washer.It will not make the final click to continue to the final rinse.This is a recent development since the washer was moved back and force in order to paint.It is the same for all wash programs.My e mail is westdon2@gmail.com
  • westdon2 Oct 11, 2010
    If the machine was not leveled correctly when it was moved contribute to the issue?
    President:
  • 1,891 Answers
The timer advance's by a motor . if it's stoping before rinse or as it inter s ck the cold water and make sure it is not a kink in the hose or that the tap is on . and if that does not correct problem then replace the timer . hope this helped mm
Posted on Oct 11, 2010
  • Kenmore Master
  • 43,501 Answers
My first thought is that this has nothing to do with moving the machine and the time of this failure is coincidental...
The timer motor has become too weak to trip the last click to get the washer into the rinse...
There is no reason other then a weak timer for this to be happening just because of moving the washer.
I would be replacing the timer if it were my machine...
heatman101
My frontload gallery series washer will start cycle, but only continues to fill with water and drain. It did this all night but didn't go on to the next stage of the cycle...is it a bad control switch
Sounds like a problem with the main electronic control board in the control panel but the only way to know for sure is to do some electrical testing with a volt meter and the wiring diagram from the machine.
Click here for: How It Works: Front Load Washer
Repair Parts: RepairClinic.com
Nov 06, 2013 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer
most likely you have a sock or, some cloth obstructing the pump.
you will have to bail out the water then: remove the Sears 700 series 4screws holding the washer's control panel and, remove the washer side clips under the panel to remove the washer's sides then remove the 8 pump screws to remove the pump face and, remove the obstruction. the
exploded drawings can be found at: http://beta.searspartsdirect.com/partsdirect/index.action
Jul 14, 2010 | Kenmore Washing Machines
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Excessive vibration
check for bearings fault,ie open door and lift inner chrome drum up and down if you feel a knocking feeling or you ear this then its the bearings
Jul 06, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
May 27, 2008 | Hoover H130E Front Load Washer
Kenmore Series 90 washer problem
i am a recently retired engineer of 20 years, this sounds like the outlet pump, maybe just a blockage, but could be a faulty unit, remove plug before checking, start with that and see how you go on, thank you, if this has worked rate me please
Sep 12, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
53 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
