Hotpoint aquarius wf321 washing machine handle has broken and door will not open and has washing still in machine
    President:
  • 1,554 Answers
The door will not unlock unless water is drained. Drain the water manually, if not from the tub by placing the drain hose into a bucket or shallow basin . Position the bucket or basin as low as possible to drain as much water. Unplug the machine for 30 minutes or so if the machine is drained but the door lock still doesn't unlock.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 11, 2010
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came lose.....open up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Noise in drum sound like its gonna blow up
hello, unfortunately the wf321 drum does not split the bearings and drum come as one complete unit and so you need to order a drum unit complete with new bearings and replace the lot
Jun 02, 2010 | Hotpoint Washing Machines
How do I repair the handle on a Hotpoint Aquarius? The handle has not come off just door catch is broken.
Remove all vvisible screws securing both parts of door, and seperate the 2 halves, be careful you do not drop the door glass.
This will enable you to see what is broken, and what needs to be replaced
Please rate my solution.
Thanks.
Nov 04, 2009 | Hotpoint Aquarius WD640 Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Dec 15, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius w.machine door catch broken.
easy way is to cut or break away the handle so the start of the door peg is exposed and use a screwdriver on the peg to lever it out
Aug 30, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Door won't open
two possibilities water not fully drained - door won't open if so handle mechanism broken - check if it too free to move or sloppy
Feb 25, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
