Question about Dell E173FP 17" LCD Monitor
Hello, my Dell E173FP 17" LCD Monitor has a blinking power light and wont turn on.
  • 11,361 Answers
It has shorted out transistors in the inverter circuits, check them out first, also check the fuse in the inverters section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Oct 11, 2010
  • soyviejodeme Mar 28, 2011
    I had the same problem and I finally figured it out.
    Keep in mind this is not a permanent solution, but if you are in a hurry or can't afford a new monitor right now, this is the way to fix it.
    If the monitor is too cold, literally, in terms of temperature, (I suppose the transistors can't charge up enough) it won't start up or will take ages to warm up. The solution is to heat up the monitor, by, for example putting it in the sun (or in oven at around less than 50 degrees celsius) for a while, and then after connecting it again, it should power up in less than 5 minutes, which in most cases is better than waiting 5 hours. An even better alternative is to keep the temperature of the room the monitor is in quite warm, and then it will always power up relatively quickly, taking around 0-5 at around 20-25 degrees celsius. I swear it works.
I have a blank Dell E173FP monitor with the green blinking light. I have ordered and received the repair/replacement parts. Can someone please respond with detail instructions to fix the problem? Thank...
yumaparkie, You mean to tell me you haven't been to YOUTUBE to see all the video clips of Dell E172FP, E173FP lcd monitors being repaired?? Do that first, then come back here if you still need help.
12fixlouie
Jul 15, 2010 | Dell E173FP 17" LCD Monitor
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
Dell monitor e17s fbp.. wont turn on
Flashing power LED light means you may have shorted (Emitter to Collector) out transistors (c5707) or bad fuse (fuse has high resistance) PF751. Those are what you need to check. see pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
http://s807.photobucket.com/albums/yy352/budm/Dell%20E15x%2017x%20series%20PWR%20INVERTER%20BD/
Post back what what you find so we can guide you further.
Feb 27, 2010 | Dell E173FP 17" LCD Monitor
My Dell monitor wont get out of the power saving mode. I unpluged and disconnected everything. Then pluged back. Still same problem.
It is more likely to be bad inverter cicuits due to shorted out transistors (four c5706/5707). The power light blinking?
Jan 23, 2010 | Dell E173FP 17" LCD Monitor
Dell e173fp monitorno power at all
If the pwoer indicator is blinking on the Dell monitor, you have shorted out transistors (C5706/5707) in the inverter circuits, also look out for bad capactiors.
Dec 17, 2009 | Dell E173FP 17" LCD Monitor
Dell LCD Monor light keeps blinking green, screen is black cannot stop blinking unless unplugged from power source but upon plugging back in monitor starts blinking green again
Your monitor has a bad power supply board. This happens often on LCD monitors because of the heat buildup in them. If you can solder them go to our web site at:
www.ccl-la.com/badcaps.htm We have a step by step dis-assembly and repair guide for your monitor. There are several versions of the E173FP some end in b , f, or c so be sure to check your monitor.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 27, 2009 | Dell E173FP 17" LCD Monitor
Dell 17 lcd.power light blinking, now test screen is there but da
look for other components in the board that are defective. drive to the back light is stil low.
Jul 31, 2009 | Dell E173FP 17" LCD Monitor
Plug Dell e173fpb monitor in power light blinks green and small buzz noise
Based on what you have stated your Dell monitor is dead. Seek support/replacement under warranty. If you purchase this with a credit card you have a double warranty through your credit card. You'll have to suffer through Dell's phone support to allow them to troubleshoot your dead monitor but be patient and a new or newer model will be on its way to you soon.
Hope this helped you and fixed your dilemma.
Worldvet
May 21, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Nov 04, 2007 | Dell E173FP 17" LCD Monitor
Monitor
i had a similar issue with my dell E172FPB, I have never seen a E173FP but this link might help you
http://syscon.wordpress.com/2007/07/13/dell-dell-e172fpb-lcd-backlight-repair/
Oct 21, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
612 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
